Question about Janome Memory Craft 9000 Computerized Sewing Machine
When i switch my 9000 on the carriage goes out and shudders and then a message comes up on the screen "Raise presser foot and needle bar then turn power switch back on" I do that with the same result. I paid $550 to have it repaired but it still doesn't work. I have taken it back to the Janome shop several times. The repair man says he put a new A board or mother board in it. The owner at the shop makes mention the machine is getting old. I had an 8000 and the screen went and it was replaced under guarantee. When I bought the 9000 the same thing happened. I have given up on Janome machines.Found this site and thought it might be worth a try.
SOURCE: Janome 9000 willl not work when turned on
My Janome 9000 has always done that. I can prevent it by raising the needle when I first start the machine, getting it to sew quickly or raising the needle and letting the machine sit for a few minutes. I think my computer wants to warm up a minute. As you can see I.m not a technical person but it works for me.
Posted on Jan 08, 2008
SOURCE: Memory Card 17
I believe only some of the '8000' cards can be used on the '9000' and this may not be one of them or it could be faulty.If you brought it from a retailer I suggest you return it explaining your problem, they may exchange or refund your money.These are 'old' cards now I believe apx 11-12 years.Hope you find a solution.good luck
Posted on Apr 01, 2008
  • 749 Answers
SOURCE: JANOME MEMORY CRAFT 8000 MANUAL
tighten the thread TENSION CONTOL.
Loose adjustment causes your problem.
if its possible for you to send me a large front picture of your machine then i guess i could give you more info. my email : jyzomnix1Yahoo.com
Posted on Nov 04, 2008
  • 19 Answers
SOURCE: says raise pressure foot and needle bar
check youre screen you will see an icon of needle you have got it in the down mode touch it it will raise it next time you sew it will be raised this is an option to have needle in fabric or raised on completion of sewing this is in your manual.
hope this helps mary h
Posted on Dec 23, 2008
SOURCE: janome 9000 refusing to start
I'll bet it's the fuse. I had the same problem about a year ago.
Posted on Mar 11, 2010
I am getting a message to raise presser foot and needle bar then turn on. The presser foot seems to be up. I dont know what the needle bar is. Please help?
The needle bar as the long vertical bar that the needle is attached to. Hand rotate the handwheel until the needle is at its highest position before it begins to descend.
Nov 13, 2016 | Sewing Machines
Does anybody know why soon as I turn the machine on it makes a weird noise and the screen says raise needle bar and presser foot. I've tried everything, can anybody help?
Hmm. Raise the foot with the presser foot lever. You have to raise the foot up to get the fabric under the foot in order to see.
May 02, 2015 | Sewing Machines
How do I fix the following problem with my Janome MC9000 sewing machine?
Unfortunately you are probably not going to be able to fix this.
It needs a sensor adjusted (probably), or a component replaced.
Sep 25, 2014 | Janome Memory Craft 9000 Computerized...
Janome 9000
Did you raise the presser foot and needle?
Oct 11, 2013 | Sewing Machines
I can't get the foot to lower and raise.
it sounds like it's out of time--here's how to fix it
to adjust the pressure on the presser bar and in turn the foot, locate the thumb
screw at the top of the machine
by rotating the thumb screw clockwise, you will increase the pressure, a counter
clockwise turn will decrease the pressure
the correct height of the pressure foot from the needle plate is 7mm.
to adjust this clearence loosen the screw & adjust the pressure bar through
the guide
secure the screw firmly when the correct adjustment is obtained
the distance between the presser bar lifting arm & the presser bar guide should
be 0.5mm ..( be sure the needle bar does not rotate left or right during the
adjustment process. the needle must be center of the presser foot & needle
plate hole,, if this is not centered re-adjust to the center of both needle foot
& needle plate hole.
Apr 07, 2012 | Sewing Machines
My brother CE 4000 sewing machine freezes. After some tinkering I can sew a little then in happens again. It makes a shuddering noise then freezes and shows an E6 error message?
Turn off the power and remove the needle and presser foot.
Remove the needle plate, bobbin and bobbin case.
Clean the shuttle and surrounding area.
Replace everything.
Make sure the flat side of the needle faces to the back of the machine.
Raise the presser foot and re-thread the machine.
Mar 06, 2010 | Brother Sewing Machines
Says raise pressure foot and needle bar
Dec 18, 2008 | Janome Memory Craft 9000 Computerized...
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Janome Memory Craft 9000 Computerized Sewing Machine Logo
63 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
