Click on this link below and download the Dell 926 AIO software and driver files for the Windows Vista 32 Bit operating system:
Dell Photo All-in-One Printer 926, v.G5, A00
This package includes a Vista Cleanup Assistant to remove older Dell printer software from your computer that may not be compatible with Windows Vista after upgrade.
http://support.us.dell.com/support/downloads/format.aspx?releaseid=R166248
Not sure if you have windows vista , xp or 7. Depending on the operating system I would recomend you to first uninstall the software for the printer and then download the updated software and then install them. Note before installing it please unplug the printer from the computer.
http://www.givemefile.net/drivers/printers/dell/all-in-one_printer_926.html
After installation or in the process it will ask for the printer to be plugged in.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Make sure to clear any print jobs in the queue and properly shutdown the computer along with the printer (pull out the printer's plug). After like 5 minutes, turn them back again and see if you can initiate a print.
Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
If your Dell 926 fails to recognize the print cartridges after following the above instructions,
take it to a repair shop for servicing.
Good Luck and Happy Printing
Lift the printer unit up. Position the scanner support beam between the tabs to hold the printer unit lid open. The ink cartridge carrier moves to the loading position in the center of the printer.
Press down on the lever in front of the right and left ink cartridges lid. The lid opens and raises up.
Remove the color and black ink cartridges from the carrier. Inspect the cartridges to ensure that it is compatible with the Dell 926 printer. The proper cartridge is called Dell 926 Standard Capacity Color Ink and Dell Standard Capacity Black Ink.
Examine the cartridges for any tape over the ink nozzle. New cartridges have a strip of tape covering the bottom of the cartridge that must be removed before installing into the printer.
Insert the cartridges into the carrier so the label is on top with the color logo side going in first. Press the lid down to snap it into place.
Push the scanner support bar back to release it. Lower the printer unit until it is closed.
Turn the printer off. Restart the computer. Turn the printer on. If the error message appears again, the cartridges may be defective and needs to be replaced.
I hope this clears up your problem.
Good Luck and Have a Nice Day!!
My OS is vista. I have both 32 and 64. I've tried going to the web site and downloading but the site gives me this message "Some technical problems" Do you suggest I use the 32 or 64 and is thereanother site you can suggest I can download file from
