Question about Apple iPod touch
Charge My Ipod touch will not charge or hold a charge for very long
  • 80 Answers
Check your usb if its still ok or the battery may need replacement.
Posted on Feb 06, 2010
Ipod touch wont hold charge
Depending how much gigibites it has and how often u use it. I have an ipad with 16g and it works great. But when its charging and i use it it really doest hold much. Hope this helps
Mar 13, 2012 | Apple Ipod Touch 3 3rd Gen 3g Mp3
My ipod touch will not take a charge
1. Check if the pin of the mobile charge inlet is bent.
2. Check the charger releasing the desired Out put voltage.
3. If all these functioning check the charge taking part have a continity.(multi metre) if no contineuty the fusing resistor burned out. Replace or short it.
Oct 03, 2011 | Apple iPod touch
Ipod touch does not charge?
try to plug it in to charge ,and then hold down the sleep and home button until it turns on.
Apr 13, 2010 | Apple iPod touch
Ipod battery won't hold a charge
i have an old ipod that I would like to download the songs to itunes and then my iphone. Ipod will not hold a charge and it intermintent when plugged in?
Dec 29, 2009 | Apple iPod touch
What do i do when i my ipod touch says ipod touch says ipod is disabled
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Sep 07, 2009 | Apple iPod touch
Ipod touch will not charge r connect to computer
Jamo i200 doesn't charge iPod Touch
have you tried changing the charger or charging it through a computer. some chargers are too outdated for the ipod to charge!
Jun 20, 2009 | Jamo I200 Ipod docking station
New iPod touch does not fully charge
To fully charge takes about 4hrs. The first 2hrs are a fast charge bringing it to about 80%. The following 2hrs are a trickle charge to bring it to as near to 100% as it can get. It is possible that the iPod hasn't yet calculated what 'Full Charge' is yet based on your devices installed battery. Give it a few days. If it still does this after a few charges and near complete discharges then do a reset. to do this, while it is on press and hold the Menu and Standby/Power buttons for about 10 seconds until the Apple symbol appears. This should get it to do a self test which will re-analyse the battery.
All the best
Sean
PiDigital
Dec 27, 2008 | Apple iPod touch
My Jensen ipod docking system wont charge my i touch
The older ipods charge using 12v, the newer ones (including the Touch 2nd gen) use 5v. So a lot of docks that will charge a nano will not charge a new Touch. If a dock says it will work with the iPhone then it will work with the newer iPod Touch (2nd gen).
If you have an old dock and want to charge a new Touch (sounds like the case here) then you can get an adapter. Scosche makes one just for this.
Dec 26, 2008 | Audiovox JENSEN IPOD DIGITAL DOCKING...
Itouch charging
Some speaker systems which are only compatible for charging the ipod nanos and classics do not work with the iPod Touch and the iPhone, the internals are slighly different from one another which will not allow that speaker system to charge your iTouch.
To play & Charge your touch, i suggest getting a speaker system that supports the iPod touch platform.
Hope this helps ?!
Oct 28, 2008 | Apple iPod touch
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
