Question about GPS
My gps Mio c310 won't turn on, and it is having problems charging. Please Help me....
  • 4 Answers
SOURCE: My GPS doesn't turn on
You need to purchase a new battery.
Posted on Feb 09, 2009
SOURCE: MIO DIGIWALKER NOT TURNING ON
hold the power button down for about 10 seconds. This will cause the thing to reboot....mine did the same thing. it will restart and should work ok.
Posted on Aug 04, 2008
freelander72
  • 124 Answers
SOURCE: battery for a Mio C310
manufacturer
Posted on Aug 13, 2009
rylee_smith
  • 8619 Answers
SOURCE: replace battery on mio C310 gps
Hi
Thanks for using FixYa. The battery replacement in Mio C310 Gps is fairly easy. You can perform the repairs if you have the following equipments--
Tools required: -precision screwdriver set -wire (24 gauge or smaller) -shrink wrap or electrical tape -wire cutters/stripper -multi-meter -sharp utility knife
Please follow these steps--
  • Remove the rubber caps and two Phillips head screws at the bottom of the unit (don’t lose the screws!) Gently pry the back off starting at the bottom and then work your way up the sides. If you hear the sound of crunching plastic please re-read the first word in the above sentence.
  • Once the back is loose you can pull it down and then away from the main body. Be aware that the speaker wire will prevent complete removal of the units back.
  • Disconnect the speaker wire plug from the main board and set the back of the unit aside. The only thing holding the circuit board in place is the USB port. Simply pry the bottom of the case slightly and lift out the circuit board. There is a ribbon cable attaching the circuit board to the display so be gentle with this.
  • Six clips (three on top and three on bottom) hold the screen in place. Pry the top clips back slightly and remove the screen. Now you’ll be able to remove the batteryu and install a new one.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 12, 2009
SOURCE: MIO GPS C220 not going any further
mise a jour mio c220
Posted on Mar 08, 2010
I have Mio C310 it does not turn on. even pressing rest.
Plug the GPS into your car, then slide the ON/OFF switch, located on the bottom of the GPS, then set it to 'ON'. Then the system should automatically start up.
May 15, 2011 | Mitac Mio DigiWalker C310x GPS Receiver
How can i get a manual for my c310
Try this link:
http://service.mio.com/M0100/F0110_FileReader.aspx?fileid=102591
Feb 23, 2011 | Mitac Mio C310 GPS Receiver
Mio C310 maps are out of date
from mio online or from mio distributors - harvey norman etc. Your software will be updated to miomap2008 also (which is the same as the navman software).
Feb 19, 2010 | Mitac Mio C310 DigiWalker GPS Receiver
How do I upgrade my c220 PDA nav system.
mio just offered update for $59.95 at mio.com
Jan 31, 2010 | Mitac Mio C310 DigiWalker GPS Receiver
I live in Australia and I purchased a MIO C310 car navigation system in Aug 2007. I would like to upgrade the map to the most current available, How do I purchase it
I did not solve it, I didn't realize that there is no simple internet sight that I could find to upgrade the map so I give up and use what i have. Thank you
Sep 17, 2009 | Mitac Mio C310 DigiWalker GPS Receiver
No signal at all.
make sure the battery is fully charged its searching mode and the battery on GPS may be too low
also make sure you are operating in an area the gps internal arial can see the sky
Jun 22, 2009 | Mitac Mio C310 GPS Receiver
Need mio digiwalker c320 owners manual
it's on your c/d that came with unit or go to http://service.mio-tech.com/
May 08, 2009 | Mitac Mio C310 DigiWalker GPS Receiver
Mio C 310 GPS lost signal
try rebooting by turning off switch on back and turning back on.
Call mio support for additional help. they are good.
Jan 22, 2009 | Mitac Mio C310 GPS Receiver
Mio Digiwalker C310
Turn off the power switch on the bottom of the unit for at least 30 seconds
Aug 25, 2008 | Mitac Mio DigiWalker C310x GPS Receiver
GPS Logo
407 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
