I think my fan burned up in my Toshiba Satellite laptop ,but was still working alittle bit then just like that would loose all power and wait a couple days and it works alittle while do the same thing ,but now the charger light comes on and the power button light won't work to power on does this happen cause of the fan not working??
  • 12,061 Answers
Well it is indeed possible that the Processor overheated and ruined itself due to that, unfortunately. But from what you describe I wonder if it isn't more of a Power Supply fault? OR maybe your power adapter is faulty?
Posted on Feb 06, 2010
What does it mean when my toshiba satellite L645D -S4040 is plugged in and only two lights come on and no power up and do not hear fan or the RAM running at all.
Sounds like you have a bad motherboard, oh and you can't hear RAM, either it's been hit by a power surge or it's burned out...
Oct 08, 2013 | Toshiba Satellite L645D-S4056 laptop
Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
Jan 10, 2013 | Computers & Internet
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite Not working
Do you get any power when you try to turn it on? Is there anything that displays on the screen?
See if it is out of warranty for sure. Call Toshiba. If it is, then you might try to remove the compartment lid that has access to the CPU fan/heatsink. Look for clogged lint in the fan. Remove it if possible.
Feb 05, 2009 | Toshiba Satellite A60 Notebook
Toshiba Satellite A105 laptop keeps shutting off for no reason.
I think your fan might be broken....if the fan doesn't cool the pc,the processor or the chipset will automatically shut down the pc to prevent burning hardware.Or your hard drive might keep crashing.Oh yeah and abstract from this i don't recommend ever using mcaffe
Oct 25, 2008 | Toshiba Satellite A215-S7422 Notebook
Toshiba M35X S149, DC jack loose
Try this simple solution. Things get knocked loose all the time. Unplug the laptop and remove the battery. Undo the screws the cover the Memory modules on the bottom of the laptop. Remove then firmly re-seat the cards. Be aware of the retaining clips holding the cards in.
Replace battery, plug in, and boot.
Hope this helps, and you have nothing to loose but a little bit of time.
Jimzer
Jun 11, 2008 | Toshiba Satellite M35X-S149 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
