Question about Samsung SGH-D900 Cellular Phone
Phone keeps on vibrating
Every time u open the fone it keeps vibrating till its closed again , very annoying! Please help
  • Anonymous Mar 30, 2014
    i have one nokia c3 phone and i dont know how to close the open apps. as i am not able to locate where to find this as opening lot of apps my phone is hanging all the time and i have to restart the phone again which is time consuming
    President:
  • 1,017 Answers
Slide tone (Menu 9.4.5)
Use this menu to select the tone that the phone
sounds when you open or close the phone.
Change this tone (vibrate) to another sound, in the Menu.
Posted on Feb 21, 2008
Please help my fone don't wanna take pics or vidio it shows close apps than try camara again
And did you close any apps already? I think the phone wants to make some memory free, for the camera app to work, and to sore the pictures or video you want to shoot. Rebooting, does not close apps.
Oct 01, 2014 | RIM Blackberry Curve 9320 Smartphone -...
Phone won't start up. just does a constant loop of the word sony then goes dark and does it again. over and over. have held down power button and volume buttons at the same time. Vibrates, then keeps doing...
If the phone is unlocked you could have gotten it stuck in a loop. I had similar problems when I flashed a ROM that was not meant for my phone onto it. If you have a backup saved you will need to re-access the boot loader and reload the backup of the saved ROM. If you can not access the boot loader I would suggest taking it to a cell phone repair shop. It would not be a difficult fix for them since it will most likely be flashing a couple of files to your phone.
Sep 10, 2013 | Sony Xperia acro S LT26w Unlocked Quad...
Phone keeps buzzing when closed, (not call alarm) seems possibly to be to do with outer screen. Most annoying
Make sure vibration isn't triggered while in your pocket. Or keep phone silent. Or its something else take battery out and reset functions
Nov 26, 2012 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
I am having trouble bleeding my brakes on a ford courier there is no pedal there when i have bled the brakes and i have also tryed changing the master cylinder and it is the same
Start by bleeding master cylinder, will take two to do this, have some pump the brake paddle about ten time every time, have them pump it and hold it down while you open brake line when paddle goes to floor close and pump again ( one of the brake lines at the master cylinder ), keep doing that till no more air comes out, then do the other brake line at master cylinder again till no more air comes out, keep an eye on master cylinder that it don't go low on brake fluid or you will have to start all over again, how go to right rear wheel and bleed till no more air comes out ( have them pump brake paddle and hold while you open and close bleeder valve, do not let them release brake paddle till you have close bleeder valve, keep doing that till no more air comes out, then go to right rear, then left rear, from there right front and last left front.Hope this was very helpful, good luck.
Jan 28, 2010 | Ford Escort Cars & Trucks
Keep hearing "command not recognized"
well. the problem is that you're probably hitting the command button where you sumbit voice commands like: call "mom".
its a stupid thing to put on a phone, and I've never seen anyone use it. but whatever, verizon's stupid.
again, the voice command key on the enV is the clear button. so if you hold it down, you'll hear the "command not recongnized, after you hear "please say a command".
your hearing it over and over again because you accidently hit it, and since you dont say anything after the beep it gives, it goes "command not recongnized". i dont think it says "please say a command" when its on vibrate, but i couldnt be sure.
hope i helped :)
Jul 20, 2009 | Verizon Communications enV2 Cellular Phone
My xbox says open tray when there is a disc in it
common xbox flaw mine does the same ,just keep opening and closeing the tray till it reads the disk,this can be very annoying .your dvd tray is probally on the way out
Feb 26, 2009 | Microsoft Xbox 360 Console
N73 vibration problem
format ur fone
1) turn ur phone off
2) press green call button + 3 + * and turn it on keep holding these buttons see if its solved
NOTE:- back up ur data first on pc
May 29, 2008 | Nokia N73 Cellular Phone
SPH-M300 continuous vibrate
I can solve this problem drop the phone on the floor, the problem is that the programming of the phone has messed up and is keeping the vibrating going so either buy new phone or keep dropping the phone till it stops vibrating
Jan 26, 2008 | Samsung SPH-M500 Cellular Phone
My w850I has been wet 4 along time wont work
ITS PROBABLY CHEAPER TO BUY A NEW PHONE WATER DAMAGE ALWAYS DESTROYS ELECTRONICS
Jan 17, 2008 | Sony Ericsson W850i Cellular Phone
How to swich off sound when
side of the phone is a volume key when first open phone or even closed press the down arrow key on the side of the phone will turn down the phone press enough times & will put phone to vibrate.
Sep 06, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
276 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
