Question about Maytag EPIC MFW9700S Front Load Washer
Maytag 3000 series locked close and inoperable
I own a maytag 3000 series washer, and the lock will not disengage. This happened after it went into spincycle and the legs were not all level and it went into a crazy thunderous vibration. by the time I got to it, it was out of control. I pushed the pause button, but it continued to spin. I held down the power button, and it did not work. When it finally stopped, the lock never disengaged. I unplugged it and plugged it back in, and tried to power it back on and all I get is 3 quick beeps. The lock will not disengage. Any ideas?
  • 1,531 Answers
If there is still water in the machine then you need to drain the water.
this can be done by using a wet dry shop vac and attach it to the end of the drain hose and remove the water that way. this will normally unlock the door
also check the wiring to the drain pump this does effect the door. you may aslo try pushing the clear or cancel button for three to five seconds.
i hope this was helpful to your problem.
Posted on Feb 06, 2010
Testimonial: "I will have to get my hands on a wet/dry shop vac, but the super quick response is greatly appreciated. Hope it works."
  • 24 Answers
I had the same problem... came to this thread and took seth's solution.
It immediatelly unlocked the door... so that was great. The problem is that while the door was unlocked,the problem remained. I tried restarting the washer but the same thing happened.
I noticed that the pump wasn't working as the machine attempted to spin. So I went on a fact finding mission.
First, turn the machine off and unplug it.
The machine has 3) 1/4 head screws on the botttom panel that I was able to reach with a cordless screwdriver and an extension. Once the screws are out, the panel slides down and pulls out.
The pump is directly in front of you. If you still have the wet/dry vac available, use it as was described in the original solution to get as much water out as possible.
When you're satisfied that you've got as much out of the machine as possible, it's time to take a look at the pump again. There is a large plastic screw plug that is facing you. Its only hand tight, so go ahead and remove that large plug by turning it counter clockwise. Don't be surprised if some water leaks out. The less you sucked out with the vacuum, the more will come pouring out. It's probably a good idea to switch the vac back on as you unscrew the plug, this will **** most of the remaining water out of the way and keep it off your floor.
OK... the plug is out. Get a flashlight and look straight back into the hole and see if you can see any obstructions... if there's anything in there that doesn't look right, either pick it out by hand or... since you have it handy... use that vacuum to pluck it out. I was lucky enough to find a pink hair tie in mine that looked out of place....
So, clean up the plug and pop it back in there. Hand tighten it all the way (clockwise) until it hits the stop.
Now, while you've got the thing apart and the water is out... if your feeling a little bolder, the pump is to the right of the plug. The pump can be removed by turning it counter clockwise. There is a plastic lock tab at the top of the pump (12 o'clock position) that will prevent you from doing this by accident. Use a flat blade screwdriver and apply a bit of pressure to the tab to allow the pump to turn counter clockwise. It only turns a little bit until the tabs align for it to be removed by simply pulling it out.
Now you can take a look at the pump and see if there is anything wound around the propeller. I had a long thin balloon that was wrapped around mine... but you may be lucky enough to find another prize....
Once you're satisfied that the propeller is clear, then remount the pump.... be sure that it is solidly engaged all the way around or else you'll get a nice puddle as soon as you start up the machine... and turn it counter clockwise, making sure that the locking tab in the 12 o'clock position again obstructs removal of the pump.
Dry up any water that might have dripped out of the pump as best you can...
Plug it back in and go ahead and give it a spin. If everything checks out, put the bottom cover back on and don't forget the 3) 1/4" screws. Also remember to remount the drain hose...
I hope this helps someone else... it's a 15 minute job if you've got the wet/dry vac, it just took me about an hour to get to the point of figuring out what the problem was...
Posted on Apr 01, 2010
  • PFFB Apr 01, 2010
    Quick edit... When you're remounting the pump, you have to turn it clockwise, not counter clockwise like I just posted (facepalm).
Maytag series 5000 washer will not power on
Unplug it for a minute or 2. See what happens. Make sure the child lock is not active.
Oct 22, 2017 | Maytag Refrigerators
How do I get the door to open on a Maytag washer that remains locked?
It sounds like the timer is defective. You may need to call a Maytag sales and/or service center and ask them what to do. WIll the washer start a new cycle?? If so start a new cycle and swee if the machine will get past this sticking point next time.
Sep 08, 2014 | Washing Machines
Maytag 3000 series
I had the problem recently with my stupid Maytag, and the internet is loaded with complaints about Maytag washers. Unfortunately, it isn't Maytag any more, Whirlpool has purchased Maytag and several good brands and ruined them with 3rd party cheaply made junk components. What used to be metal is plastic now, and cheap plastic at that. I had the repair man out 2 times while still under warranty, and then 2 months after warranty expired again the on/off switch failed. No more Maytag products for me.
What I did was unplug the washer for 1/2 hour, then re-plug it in. Then I held in the start button for about 30 seconds and let it go. After it sat about 10 minutes, it suddenly released the catch. I can't guarantee this will work for you, but worth a shot.
Sep 28, 2013 | Dryers
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag front load washer, MHW 3000 series, f22 error message
This is a problem with the door not locking shut. Maytag have an ecellent technical assistance page on this problem with diagrams and stuff. Go to:
http://maytag.custhelp.com/app/answers/detail/a_id/2889/~/display-shows-f22-or-fdl---front-load-washer
and take a look
Jun 30, 2011 | Maytag Washing Machines
What does an f22 error message on my Maytag 3000 series washer mean?
F22 is door lock error. This is usually fixed replacing the door lock. Connection from door lock to CCU (control panel) may also be responsible.
Nov 01, 2010 | Washing Machines
Just bought a Maytag 3000 washer and dryer and
Most likely the metal is aluminum or stainless and you should worry about rust unless you wash your clothes with salt-water (seawater. not gonna happen.)
If you're really concerned, I'd attempt to reach a maytag customer service person.
800-462-9824
To reach a real person press 0 at every option. Should take three times.
May 11, 2009 | Maytag Neptune MCE8000AY Electric Dryer
DOOR HARD TO CLOSE
need your door lock assy replaced
Mar 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Lid Lock Replacement
I have replaced my right lid lock twice and the second one just went bad. The left one does not matter, only the right one tells the washer the lid is locked. I think the bleach cup is the problem, bleach corodes the metal contacts in the lock. Try removing the plug and cleaning the contacts. I am going to bypass this lock I am not buying any more parts for this unit!
People have reported replacing this lock several times in unser two years.
Aug 30, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
1,722 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
