Question about Canon i80 InkJet Printer
I just changed the Black ink cartridge and when the print printer head moves back and forth it made a griding noise and stopped and now I have two yelloe lights blinking. HELP
    Guru:
  • 161 Answers
Maybe it is not installed properly..by the way where do you purchase your cartridge..is it brand new or just a refill???if that is a refill maybe the sensors are damage..if brand new..check if you have some spilled ink inside...you need to clean it and try to run test using your printer troubleshooter
Posted on Feb 06, 2010
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Printing a table the vertical lines shift left/right about the width of the line as the head moves back & forth. This only occurs with the black cartridge in use, not the color cartridge. The black...
sounds like you replaced the black cartridge, do you run the "align print head" on the printer. Sounds like the black is not aligned to the printer input.
Jan 10, 2018 | Hummingbird CannonLink Ink Feed System
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
Printer does not print but on screen message is "printer cradle cannot move". Print would move back & forth @ one end, moves to the other end to repeat the back & forth movement and then stop with...
This generally occurs when the tracking ribbon becomes dirty and the print head travel cannot be tracked. Open the cover as you would to change your ink cartridge and locate the clear plastic strip behind the print head. Very gently wipe the ink residue from the strip using a cloth damp with water. You should be able to move the print head manually enough to clean the entire strip. Again be very careful as the strip hooks on the left side and is very difficult to reattach.
Aug 11, 2009 | HP DeskJet F380 All-In-One Printer
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Cant change ink cartridge on my Epson C91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
May 02, 2009 | Epson Stylus Photo 1400 Printer
Hi, I haven't used my Canon S330 printer for some months, and when I plugged it in just now, it wouldn't print. I replaced both cartridges, and still no printing. The cartridge moves fairly quickly back...
in the print head there are hundreds of minute holes from where the ink of the cartridge comes out when you remove the head check whether the ink is coming from the holes in the head .if the ink is not coming the head may be dry and if the very less ink is coming then some of the holes are blocked. the ink has to come out from that holes for printing.
thanks.
Sep 18, 2008 | Office Equipment & Supplies
Changing the ink cartridge in Epson Stylus CX4200
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
May 15, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson c60 printer
Common problem with Epson Printers.
Either the print head is clogged, or the tube that goes from the pump to the printhead fell off.
Open the printer cover so that the ink cartridges are in open view and then UNPLUG THE PRINTER" so that the ink cartridges wont go back to home position. (If there is a change INK cartridge button, then press that then uplug the printer when the cartridge stops moving.)
You can try to clean the print head by folding up a couple paper towels, then saturate it with windex with amonia. Place it under the print head assembly and manually move the print head assembly over the paper towel back and forth to clean the bottom of the print head assembly. You should start seeing ink on the paper towel.
After cleaning, run the cleaning program that Epson has, and try it out.
If it still doesn't work, then you might have to repeat this a couple more times.
If it still doesn't work, then it might be time to get a new printer.
Hope this info helps.
Good luck.
Mac
Feb 07, 2008 | Office Equipment & Supplies
Printer makes noise while cleaning heads
Grinding noise is most likely caused by the carriage lock getting stuck and holding the print head at the home position. The noise is caused by the toothed belt that pulls the head back and forth, skipping over the splines on the motor drive wheel. If you have been able to print since the problem occurred, chances are that it has freed itself up and will be fine. Regarding the loss of cyan & magenta output, follow the solution given in my previous posts to complete a manual under-head cleaning cycle. This should get you going. Check this previous post for cleaning info: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 05, 2007 | Epson 1000 ICS All-In-One InkJet Printer
Canon i80 InkJet Printer Logo
111 people viewed this question
old marine
old marine
