Question about Sewing Machines
After sewing what looks like perfect stitch for one inch to 1 1/2 inches, it stops sewing, won't feed item through anymore. When pulling garment from machine, bobbin is tangled up with thread and has to be cut loose. I rethread bobbin afer clearing tangled threads out of way, it will sew and additional inch, then go the same thing all over. I tried pulling all thread off bobbin, replaced it and it still does same thing. I have a singer sewing machine approximatly 34 yrs. old.
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 46 Answers
SOURCE: Sewing Machine: loose stitch that's easy to pull out.
Check that the upper and lower threading are correct. Check that the thread has tension from the bobbin case.
Posted on Jul 25, 2009
mohammed387
  • 1952 Answers
SOURCE: i have the basically the same problem. i was
Check the easy stuff first:
Make sure the needle is inserted in the machine properly- a good rule of thumb is the flat side of the needle should go to the opposite side of the last thread guide. Also make sure the machine is threaded correctly.
the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly.
the needle is in the machine correctly- all the way up into the needle bar, make sure that it is threaded correctly, etc. If this all checks out ok, take the bobbin case out of the machine. There are two ears on either side of the bobbin case- turn the left one to the left and the right one to the right. Remove the silver ring, and inspect the piece of metal that the ring came off of (looks like a circle with the top cut off). You have to locate the hook which is the piece that looks like a half moon inside the big round metal piece. Locate the tip of it, turn the handwheel toward you until the needle is in the lowest position, at this point the tip of the hook should be flush with top of the left side of the cut off circle. If this is not so, your machine needs to be re-timed. If that is the case.
Posted on Aug 04, 2009
  • 15 Answers
SOURCE: Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Posted on Sep 06, 2009
New project call for stitch length of 12. Is that about a number 2 on my 153 machine
The 12 probably refers to the number of stitches to an inch, so probably a 2.2 to 2.4 may be sufficient. A setting of 2.5 is probably closer to 10 stitches per inch. Twelve stitches per inch is good for most garment stitching. The stitches are not too far apart to allow popped stitches under stress and gapping between stitches nor too close together that would make it difficult to remove stitching when correcting a mistake.
https://www.quiltingcompany.com/understanding-stitch-length-quilty-pleasures-blog/
https://www.google.com/search?q=sewing+machine+stitch+length+gauge&ie=utf-8&oe=utf-8&client=firefox-b-1
Feb 27, 2018 | Sewing Machines
I want a 1.8 stitch length to paper piece ... I can't figure out how pfaff creative changes to 1.8
Looks like your machine's stitch length ranges from 0-6 mm. So you are looking at something just under 2 mm--there very possibly is a 1.8 setting on your machine. Basically, your paper piecing instructions are telling you to set the machine to stitch somewhere between ~12 to 14 stitches per inch. The accuracy of 1.8 is Not that important. What they are trying to do is make sure your stitches are close enough together to make it easy to tear away the piecing paper. When using longer stitches for paper piecing, it is sometimes difficult to tear away the paper without pulling the thread stitches. Most garment stitching is set between 10-12 stitches per inch. So you want something just a little closer together, ie more stitches per inch. If you are concerned, try it out on a scrap piece of paper and fabric and try tearing it away. If it works, then that's all you need to use.
Setting Stitch Length Quick Look at How and Why Sew4Home
Mar 11, 2017 | PfaFF Sewing Machines
Foot feed stopped working
Manually turn the handwheel. Are the feed dogs still moving but remain below the sewing surface so they do not contact the fabric? Check to make sure the feed dogs have not been set to the darning function. Also set the stitch length to a 10-stitches per inch to see if that makes a difference.
Sep 26, 2015 | Singer 7422
Where are the gathering and basting stitches located?
I put them just inside the 5/8 inch seam line so they will not show on the outside of finished garment. You don't have to remove them then, but you can if you want to if they are easy to remove. Of course if you have to re-fit you may need to pull some or all stitches out. I usually do the basting stitches by hand (depending on the item) and they are easy to pull out. If you use the machine for either, be sure to use a long stitch.
Mar 07, 2015 | Sewing Machines
My straight stitch is not perfectly straight, what can I do?
1. Put a piece of paper on the sewing machine w/o thread. Sew for three inches.
2. Notice the needle holes are straight with the feed dogs. The pressure foot is not in line with the holes.
3. With the pressure foot down loosen the pressure foot pressure to it's lowest amount.
4. There is a screw on the arm that needs to be loosened. Afterwards, adjust the arm until the foot is parallel with the feed dogs. Tighten screw.
5. Try sewing again on the piece of paper to check for accuracy on being straight.
6. One other check is to insure the feed dogs have even wear.
Mar 04, 2015 | Brother CS-6000i CS6000i 60-Stitch...
How do i get sewing machine to stop showing code 6 when I have done everything by the book. sews perfect stitches for about an inch then code 6 and locks again?.
Since it is a computer,maybe try unplugging for about a minute and plug back in and turn the machine on. See if the code is cleared. hope this helps
Oct 02, 2014 | Brother Sewing Machines
Singer futura 900. My test stitch on a scrap material looks fine. When I sew on the actual item I wish to fix the stitches go from the 10/in to 1/inch. They are all spread out and do not hold the seam...
is the test stitch fabric the same as the actual item you need to sew, if not you might need to change the needle. also check the stitch length to make sure it's set correctly.
Jan 01, 2014 | Sewing Machines
I put on the 1/4 inch quilting foot and the machine will not hold the settings, feed: 2 to 2.5 and stitch width 0
This sounds like a stepper motor problem. When you say it will not hold the settings do the feed teeth stop moving? Your feed teeth should be 1mm above the needle plate at the highest setting. Is that working for you?
Dec 15, 2013 | Husqvarna Viking 1
Irregular stitch length in machine sewing
1. Lengthen your stitch length
2. Use your even feed foot (walking foot attachment)
Nov 30, 2012 | Sewing Machines
I have a question on my Kenmore sewing machine style 385.17626 When I start sewing, after a couple of stitches it starts to bunch up and not feed through. It's a tangled mess of thread and fabric. I'm...
Try using a double strip of tissue paper 1 1/2 x5/8 inch placing it about 3/4 inch under edge of fabric and middle of seam allowance. Start stitching on the tissue paper and continue onto the fabric to the end of seam. After that remove the tissue. You can also hold both threads and slightly pull them when you first begin the seam to help them reach the back feed dogs.
Oct 22, 2009 | Sewing Machines
Sewing Machines Logo
47 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
