Question about Refrigerators
Have a amana with bottom freezer. Everything
Have a amana with bottom freezer. Everything works expect no cold on top - temp is 60. have dthe temperate on 8
    Sergeant:
    Champion:
  • 263 Answers
Keep in mind, your fridge 100% depends on the freezer. You have a defrost system problem most likely(see if icying up in the back wall of freezer). And if so, most likely defrost thermostat went bad.
Amana refrigerator repair orange county, ca
Posted on Feb 06, 2010
The refrigerator compartment will not cool the freezer is still freezing top temp 70 bottom temp -10
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Amana ABB1927DES Stainless Steel Bottom...
I have an amana bottom freezer/refrigerator model ABB2522FEQ. the bottom freezer works great, but the coils have frozen two times. I thawed coils out again and it only lasted 2 weeks, eventhough the fan...
HI,IF THE FREEZER IS BUILDING ICE ON EVAP COVER THAT IS NOT DEFROSTING PROPERLY,REPLACED THE CONTROL BOARD AND DEFROST B-METAL TO REPAIRD THE PROBLEM..
Jul 04, 2011 | Amana ABB2524DE Bottom Freezer...
Everything in the freezer has defrosted, temp setting at 6 (refrigerator compartment at 5). Amana bottom freezer model ARB210AB Water will not freeze, ice cream melted and frozen veggies and meat have...
Is there frost on the freezer panel? are the two motor and compressor running (freezer motor and condenser motor)? find this out 1st. this is nothing you did but if you are not mechanically incline at this point only a frig tech can properly check and tell you exactly what is it. theres are the things it might be...
compressor not working
condenser not running
freezer fan not running
thermostat not sensing temp.
stuck in defrost
heaters on too long
bi-metal shorted
timer not working
now if you paid alot for this frig at least get someone to look at it for a service call ($40-60) if it too high to repair then its time to get a new one
Mar 27, 2010 | Amana Easy Reach Bottom Freezer 20.5 cu....
Amana bottom freezer refrigerator will not stay cold, temp. rises to 50-60 degrees, much to warm. Service repair came and said it freezes up. Instructed us to heat the back left side of the freezer with a...
It sounds like the drain trough heater is not working. Not a fun repair job. You have to remove everything out of the freezer and take the top panel off the top of the freezer section. Locate the heater wire that goes into the drain trough and replace the heater wire.
Dec 29, 2009 | Freezers
The lower part of my refrigerator is freezing everything (temp. approx. 30 degrees). The upper part of the refrigerator is almost 45 degrees.
it is possible that the circulating fan is knacked. cold air drops so the bottom of your fridge so will be alot colder than the top, especially since the air will no longer be circulating.
Dec 04, 2009 | Amana ATF2136ARB 33" Top Freezer...
Refrigerator is warm @ 60 degrees and the freezer is still freezing happens every so oftern
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Mar 13, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
Amana Fridge with bottom Freezer
either the switch or the temp sensor it broken. on the sears site you can get the part number
Apr 24, 2008 | Amana ABB1921DE Bottom Freezer...
Refrigerators Logo
152 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
