Question about ViewSonic VG2230WM LCD Monitor
Blank Screen Viewsonic VG2230wm 22" monitor. For the last few weeks I have been noticing that when I turn the monitor on it would bllink and go out. When I turned the montitor off and on again it would work fine. Then while in the middle of working on my computer the screen went black. I noticed that the blue light was still on, I turned the monitor off and back on but the screen remains blank. I shut down the computer and the monitor and let them set for a few minutes then turned them back on. The monitor light turned blue indicating it was on but the monitor did a quick light screen that turned black. Could it possibly be the connection in the back of the monitor? I operate my system using the DVI cable input. If that would not be the issue, I could use some ideas as to what I should check next. Thanks!
  • winnerj77 Feb 06, 2010
    Could you tell me the easiest way to get the back off the monitor without breaking it? I have removed all the screws and I noticed a small slot with a padlock symbol on it. I have check to see if there is a lever I need to press but have found nothing. Seems like there is a trick to separate the cover, can you please let me know the trick. Thank you!
  • 11,361 Answers
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Posted on Feb 06, 2010
  • Bud Martin
    Bud Martin Feb 07, 2010
    You will need flat blade screw driver or a strong tweezer (I use tweezer most of the time, see my tool album at photobucket.com). You will start at the bottom section of the monitor first, then work it all the way around, it is hard to explain. By the way, the locking key symbol is for theft security hook.
How to perform viewsonic VG2230wm red line removal?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 03, 2014 | ViewSonic VG2230WM 22 inch LCD Monitor
Removing back panel of a viewsonic monitor
There are almost always plastic clips along with the screws. I'd recommend buying a plastic pry bar. You can google for them online and they cost $1 or so.
Jan 30, 2013 | ViewSonic VG2230WM LCD Monitor
Viewsonic vg2230wm - the screen is blank when the computer first boots. I have to turn the monitor power switch on/off several times before the screen turns on, then it is fine.
Check your VGA (Visual Graphic Adapter) connector from your C.P.U (Central Processing Unit) to your monitor if it is intact. If it is intact , replace the VGA cable first. Then if the problem still persist check for the VGA driver in the device manager if it is correctly installed. If the problem persist try and send mail to me on greatengineerid@hotmail.com
Cheers.
Engr. Adewumi I.O
Sep 05, 2011 | ViewSonic VG2230WM 22 inch LCD Monitor
The screen keeps going blank
Check for bad caps with bulging tops as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VG2230WM/
You should replace them in a set.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 09, 2010 | ViewSonic VG2230WM LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
My Viewsonic VG2230wm refuses to use its native resolution of 1680 x 1050. Whenever I select this resolution, it registers on the computer display settings, but when I check on the monitor display panel...
You will need to adjust your monitor settings in the NVidia control panel. You can get to this by right clicking somewhere in a blank spot on your desktop and then selecting it from the menu. You will want to go into the Display section. If you aren't able to see that section, change from "Standard" to "Advanced" settings at the top of the screen.
Dec 31, 2009 | ViewSonic VG2230WM LCD Monitor
Vg2230wm monitor Will not power on
probably your power supply. Is it a cord direct from plug in for is there a box between where you plug it in and then a small round end that goes into the monitor. This would be the good news. If it plugs in direct then that means the power sopply is in the monitor itself which means more expensive to fix
Aug 05, 2009 | ViewSonic VG2230WM LCD Monitor
Black screen, power button flicks
The monitor should come when the power button is pressed once - period. If not, and it continues to happen when connected to another PC, then the hardware is having trouble powering up the panel / ccds and it should be replaced/serviced according to the terms of the warranty. I suggest to bring it to an authorized service center for proper diagnosis & fix the problem. regards
May 21, 2009 | ViewSonic VG2230WM LCD Monitor
Screen goes blank
abandoned problem for now. will look for inverter board or parts from another monitor
May 12, 2009 | ViewSonic 22" FLAT SCREEN CRT BLACK...
ViewSonic VG2230WM LCD Monitor Logo
1,111 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
