Question about LG enV3 VX9200 Cell Phone
My phone's battery always comes off. I think its a problem with the locking tab which might be damaged and it is loose. is there a way to fix it
Do u mean the cover?I suggest u go 2 the shop where u bought it.They should noe wat 2 do.All the best,buy a new cover or a new battery incase its spoiled.
Posted on Feb 06, 2010
I have tried mulitiple chargers, the charging port isnt loose.i took my phone batter out and put in my locker while i was at school ( 5 hours) but nothing happening
is the white tab on the battery turned pink??if so,you have water damage otherwise try a new 5 volt 2 amp charger and new battery,if nothing then your motherboard is bad.
May 15, 2015 | Alcatel T-Mobile ONETOUCH EVOLVE 3G...
CAN UNLOCK MY PHONE WITH A USB
Using software to unlock your phone will damage os and crash firmware so better use code to unlock your phone.Unlock code is the best and safest way to unlock phone.You can get the unlock code for your Alcatel phone from TheUnlockSpot.com and unlock your phone from Network lock easily.
Jan 31, 2014 | Alcatel Cell Phones
Reset computer saab
reseting the compuer [which is what ur doing when u disconnect the battery] will not solve the problem either a wire is loose damaged or shorting,or the lock mechenism is worn loose or damaged need to open the steering column and check the steering shaft lock by the key cylinder .
May 02, 2013 | Saab 9 3 Cars & Trucks
I have an Ariens snow throw and the dual handle interlock does not function. The attachment clutch does not stay engaged when the traction clutch is engaged. Thanks
I have seen two simple mechanical problems that I suggest you check first.
One, there is a little tab on one of the handles that does the mechanical interlocking. This tab sometimes bends. Look carefully at the handle pivot area and check this out. If it is bent fix it with a pliers. Sometime that tab breaks off and you will have to replace the handle.
Second, The handle itself comes loose. The pins holding the handle on come loose causing it to not engage that little tab. Sometimes the handle will come loose. Replace the pins and locking pins as needed.
Jan 12, 2011 | Garden
Motorola BC50 Camera Problem
When a phone start showing capture failed, it means that the camera of the phone damaged and needs to be replaced.
You will need to get a new camera for the phone.When you purchase a new camera, loose the phone and fix it, it will work normally.
Would advice if you do not know how to loose the phone, you can take it to a mobile phone repairer to fix it for you in other to cause further damage.
Take care.
Mar 21, 2010 | Motorola Mobility (BC50 SNN5779A SNN5779)...
The agitator is no longer attached
There is a small set screw located lower on the agitator. Locate the set screw and tighten. This should solve the problem.
Jan 05, 2010 | Maytag Washing Machines
My 2005 chevy cobalt starter is locked...thus battery clicks as if it is drained when I try to turn on car. I think the key fob somehow locked started, but I cannot figure out how to undo it...I cannot...
Pretty sure you have a dead battery. The radio and lights may come on, but if the capacity to start is not there, the starter will not turn. There is no such thing as a locked starter, as you describe.
Dec 01, 2009 | 2005 Chevrolet Cobalt
My phone will not turn on but the little red light is always on
try this: take the battery out, then hold down the red power button...keep holding it until you put the battery back in and your screen comes on. Hope this helps, it worked for my daughter's!
Jul 13, 2009 | Palm Treo 500 Centro
LG enV3 VX9200 Cell Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
