Question about Palm Treo 755p Smartphone
Palm 755p Malfunction
My 755p blinks from access powered to palm and back every 5 seconds please tell my what is wrong with it
  • 47 Answers
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your Treo, so only do it if you have to. Google how to and it will work perfect.
Posted on Feb 20, 2010
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
My palm gets blinking...after i put the battery back...it's stuck from access powered to palm...did i lose my info
no your info is still there but you have some app trying to start before the OS really starts but is failing to , then you get this blinking state. your info is still there and there is a somehow undocumented feature in the OS to avoid the palm OS to run any boot time routine, if my mind is right I think it was pressing a specific button while the splash screen is being loaded, now be carefull because with some button you will get the "erase all?" question then if you press the "up" key you DO erase all your data, this is the way out if you do have a backup and if your info between the device and your pc was in sync.
Jan 09, 2010 | Palm Treo 755p Smartphone
I am looking for the QPS Key Manual for palm treo 755p
Please follow the below link, select your carrier and you will have access to the user manual, software, updates and so on.
http://kb.palm.com/wps/portal/kb/na/deviceselector/page_en.html#NA%20Phones:Treo%20755p
Hope it helped.
Nov 20, 2009 | Palm Treo 755p Smartphone
Palm treo 755p tried removing battery and still only says treo across the screen and reset button dont work
in order to perform a hard reset, you take out the battery. hold the power button and insert the battery.
release the power button when you got palm/access powered. it should prompt you to erase all data. press up to erase and finish setting the device. no need to reinstall the palm desktop software.
Nov 09, 2009 | Palm Treo 755p Smartphone
My treo 755p is constantly going on and off by itself it goes to access powered and then palm and shuts off. It repeats the same process
send the palm treo back to your provider tell them what is happening they should repair it at little to no cost if it is not anything major.
Jul 31, 2009 | Palm Treo 755p Smartphone
My palm treo 755p power cycles to the access powered screen
There are different types of resets that may cure this issue. Try them, starting from a soft reset.
http://forum.brighthand.com/showthread.php?t=13189
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Palm Treo 755p Smartphone
Hello, have a Palm 755p Treo screen just keeps flashing
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
Apr 09, 2009 | Palm Treo 755p Smartphone
Unlock Palm Treo 755p
palm treo 755p doesnt have a sim card tray!
sorry
Mar 03, 2009 | Palm Treo 755p Smartphone
Frozen Screen on Palm Treo 755p
mayb you can try to do a hard reset.
Take out your battery press and hold end call button ( don't release ) then put in your batery wait the loading finished and change to other screen then you release your from the end call button you pressing just now.If still can't work,no choice need to go back to you service center .
Dec 28, 2008 | Palm Treo 755p Smartphone
I have same treo 755 problem, did you get it fixed?
I had the same problem, and here is how I fixed it. First, I hit the middle up/down key at the top as it was cycling between Access/Palm, and when it came to Palm, I turned it loose. This got it to go to the regular screen, but guess what....my phone would not work! So, I took it to the local Verizon dealer at Circuit City, and there I asked the guy if he would do a Hard Reset. He did, go the phone back up working again, but of course I lost EVERYTHING. Luckily, I had done a syn not too long before, and instead of telling the long story of what all happened there, I was able to get all the backed up info back onto my phone, and now everything is back to normal. This has happened to me twice (the first phone was replaced as defective, but it could have been fixed the same way). I love the Palm 755p, but be sure and sync as often as possible on your computer. It saves you from having to enter a ton of phone contacts back in manually!
Jul 16, 2008 | Palm Treo 755p Smartphone
Palm Treo 755p Smartphone Logo
231 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
