Question about Panasonic PT-61HX41 61" Rear Projection Television
I need to access set up which calls for pressing the volume down at the end of the entering setup. the problem is that i can't enter the set up due to the volume, channel buttons on set do not work, only the power button works. any idea why those buttons dont work, or is there another shortcut to enter setup mode to adjust convergence thanks
2 Suggested Answers
techman
  • 3130 Answers
SOURCE: Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Posted on Aug 12, 2007
Fix volume control
1. Go into the Set Menu.
2. Press the AMP button on the remote.
3. Press the Menu/Set Menu button.
4. Use the Arrow Up Down button to select Manual Setup.
5. Press the Enter button to enter Manual Setup.
6. Use the Arrow Down button to select the number 3 Option Menu.
7. Press the Enter button to enter the Option Menu
8. Use the Arrow Down button to select D Multi Zone Set.
9. Press the Enter button to enter D Multi Zone Set.
10. Press the Arrow Down button to get to Zone 2 Amp
11. Press the Arrow button to the right to set the Zone 2 Amplifier to INT.
12. Press the Menu/Set Menu button repeatedly to exit the Set Menu.
Aug 09, 2014 | Yamaha RX-V757 Receiver
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
Sep 13, 2012 | Panasonic Televison & Video
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
How to oprate
i do not under stand that what kind of information you want to ask from us. Now i am telling you the major function of any cellphone.
Make a call Number dialing 1. Enter the phone number, including the area code. For international calls, press * twice for the international prefix (the + character replaces the international access code), enter the country code, the area code without the leading 0, if necessary, and the phone number. 2. To call the number, press the call key. To adjust the volume in a call, press the volume key up or down. 3. To end the call or to cancel the call attempt, press the end key.
Answer or reject a call To answer an incoming call, press the call key. To end the call, press the end key.
Jan 11, 2011 | Cell Phones
Enter bios password
If you want to add the BIOS password:
  1. Restart the computer.
  2. At the SONY screen, press the F2 key.
  3. In the Setup Utility window, press the RIGHT ARROW to select Security .
  4. On the Security menu, press the DOWN ARROW key to select Set Machine Password .
  5. Press the ENTER key.
  6. At the prompt, in the Enter New Password field, enter the desired password.
  7. Press the ENTER key.
  8. In the Confirm New Password field, retype the same password.
  9. Press the ENTER key.
  10. At the Setup Notice prompt, press the ENTER key. NOTE: To set a user password, repeat steps 4-10, selecting the Set User Password option.
  11. Press the F10 key.
  12. In the Setup Configuration window, press the ENTER key.
  13. Press the RIGHT ARROW to select Exit .
  14. Press the DOWN ARROW key to select Exit Setup .
  15. At the Exit Setup prompt, press the ENTER key.
If you want to remove the forgotten BIOS password:
Please call 888-476-6972 and speak directly to a Sony® support representative for further assistance. A resolution for this issue is available, but for security purposes, this resolution can only be provided by a support representative.
Jun 12, 2010 | Sony VAIO VGN-N385E/W Notebook
Zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal power amp.
Setting the RX-V661 remote control to operate Zone 2
1. Using a ballpoint pen or similar object and press the Code set
button. The Transmit indicator on the remote should flash twice.
2. Using the numerical key pad on the remote and key in 9992, the
Transmit indicator should flash.
You will now need to assign the receivers internal amp for Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter button.
5. Arrow to the Sound Menu option and press Enter.
6. In the Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return to the Manual
Setup.
Apr 05, 2009 | Yamaha RX-V661 Receiver
How to set date and time
Voice Time/Day Stamp
1. Make sure the answering system is ON.
2. Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confirm the setting.
8. Press Caller ID-Volume to set Day
9. Press #Pause to Confirm
10. Phone will then Announce the Day & Time
Feb 02, 2009 | GE 25932 Cordless Phone
Gives wrong time and day
This is from the Manual. If you want the whole manual, at the end of the instructions, there ia a link to the manual.
Setting Day and Time
Day & Time sets the day and time of your display.
1) Enter the Global Setup menu, and then the Day & Time
submenu option (see "Entering the Menu" on
page 17). Image is for the base.(Here is how)
Entering the Menu
1) In standby mode, press the MENU soft key.
2) Use volume up/down to move the pointer to a desired
main menu (DirectLink Mode, Room Monitor, Handset
Setup, Base Setup, Answ. Setup, Global Setup, and
Deregister HS).
3) Press the OK soft key to select the desired main menu.
To return to the previous screen, press the BACK soft
key.
4) Use volume up/down to select a desired submenu and
then press the OK soft key to enter.
5) In the submenu option, use volume up/down to select
an item. Press the OK soft key to confirm your
selection. For detailed instructions, see the following
sections for the desired submenu option. To return to
the previous screen, press the BACK soft key.
6) To exit the menu, press end on the handset or cid/exit on the base.
2) Press volume up/down to select the day of the week,
and then the → soft key.
3) Press volume up/down to set hour, and then press the → soft key.
4) Press volume up/down to set minute, and then press the → soft key.
5) Press volume up/down to choose A M or P M, and then press the SAVE soft key. You
will hear a confirmation tone.
http://www.uniden.com/pdf/TRU8885-2om.pdf
Jan 08, 2009 | Uniden TRU8885-2 Cordless Phone
Speaker error
Try checking the volume on your subwoofer i had the same problem. I unplugged the system and had the same error message pop up. So i checked the volume on the subwoofer, and it was set to max, i set it to normal and i haven't had any problems since
There are 2 ways to check your volume
1...On the remote there is a button labeled "BASS" press it, and on the display it will tell you a number between -3 and +3, If no number appears then it should say either "MIN" or "MAX" if it's at max use the volume control on the remote to turn it down to "0"
2...On the remote press "SET UP"
.....Select the Volume icon by using the arrow keys, press "ok" or "enter" to access that icon
.....Select "Speaker Setup" using the arrow keys and enter button
.....Select Speaker Volume by pressing enter
.....scroll down to "SUBWOOFER" and make sure the volume is no higher than +4dB
....Once done press "SET UP" on the remote to exit the setup screen
*Note* - The speaker volume option can only be chosen when nothing is playing on the player, or the disc tray is empty, You also have to be in either, Ipod mode or DVD mode to access this menu.
Hope this solves your problem, and i apologize on the delay of this solution ^_^
Oct 25, 2008 | Yamaha DVX-C310SL System
Panasonic PT-61HX41 61" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
