Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Can not install drivers on my new widow pc. It only has a 500 gb harddrive. could this be the problem?
  • 838 Answers
Hi, welcome to Fixya.
Can you please tell me what are the drivers.
Thanks
Posted on Feb 06, 2010
  • Mohd. Tareq
    Mohd. Tareq Feb 06, 2010
    You written your hard drive is 500GB, Can you tell me the requirement it leveled on disc or manual to install the driver. I think there is no program or soft takes 500 GB to install. Can you tell me your system information also.
    Thanks
Drivers windows 7-64 laptop needs drivers for hitachi hts545050b9a300 500 gb external drive
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Jan 14, 2013 | Hitachi (hts545050b9a300) 500 GB SATA Hard...
I have a acer aspire 3684NWXMi series with a 80 GB hard disk drive and want to upgrade to the 320 - 500 GB do I have to buy a certain make or brand for it to work in my laptop?
According to this review there is no optical drive, (CD/DVD drive),
http://www.naaptol.com/laptops/acer-aspire-3684nwxmi/P/779.html
The new harddrive is blank. No Operating System on it.
No Windows.
After a person installs a new harddrive, the basic procedure is to use the Restoration Disk, and when asked choose Full Install.
(Destructive Installation)
No optical drive.
[No Restoration Disk is NO problem. Contact HP Support.
In the US it is $17 for a 5 to 7 day ship, $24 for a 2 to 3 day ship.
Have more info for US, and other countries if you need it ]
This means you will go through some 'changes', if no optical drive.
More than I believe you may wish to take on.
(Don't want to overstep myself, or seem rude)
The next thing is there may be a harddrive limit.
Might be capped at 135GB, and not allow a 300, or 500GB harddrive.
If this holds true the harddrive is then partitioned;
300GB harddrive;
Partitioned into 3 partitions, of 100GB each; or 4 partitions of 75GB each.
500GB harddrive;
Partitioned into 4 partitions of 125GB each.
Fools BIOS into thinking there is just a 75GB, or 100GB, or 125GB harddrive; instead of a 300GB, or 500GB unit.
Yes. More headache if you may not be adept.
I suggest using an external harddrive instead.
Just my thoughts,
Regards,
joecoolvette
Dec 14, 2012 | Computers & Internet
My segate expansion portable drive 500 gb not work from my pc
Has it worked in the past or is this a new drive?
if this is a new drive, make sure it's connected to yout computer and installed (there may be some drivers that are required from the vendor - perhaps on cd/dvd)
Also, you may need to format the drive in order for it to work.
Jun 06, 2011 | Computers & Internet
I was given this qosmio f45-av411 and it had no hard drive i have a seagate momentus 5400.6 500 gb hard drive but when i install and go to the bios it is not recognized
Have you checked the maximum capacity and harddrive specification that your laptop could handle? You might be using a harddrive specs that exceeded the maximum. However, try to check if it is properly seated first before trying to use lower specs of harddrive.
Hope this helps.
May 20, 2011 | Computers & Internet
My Seagate FreeAgent Go 500 GB, stopped working in the middle of copying some of its data into my PC. Now instead of the constant light-up when connecting to the pc, it blinks continually. And the hard...
First i would remove and reinstall drivers for this device,next try device on another system if it works ok on another system drive ok if not drive has failed.Good luck!!!
Jan 08, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My 500 GB will not turn on properly. I've tried rebooting a couple times, but everytime a solid red light comes on. If i try restarting using the Power button the redlight begins flashing. Trying to...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Sep 13, 2010 | Iomega (33275) 500 GB USB Hard Drive
I have an HP Pavilion dv9000 purchased in 2007, 17" widescreen. Currently it has a 140GB harddrive that is almost full. I purchased a 500 GB harddrive to replace it but my computer won't acknowledge the...
It has to have SATA Hard Drive Connector DFHS22FR685, if you have this then I would try to format the hard drive to what your operating system is using, either NFTS or FAT32. The drive may not be properly formated for your system.
Jan 22, 2009 | HP Pavilion dv9000z Notebook
Computer suddenly not reading external harddrive
I managed to fix it by unplugging the harddrive from the main electrical power source.
Nov 23, 2008 | Western Digital 500GB My Book World...
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
Top Arris Computers & Internet Experts
Jerry
Jerry
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
