Question about Isomac Millenium Espresso Machine
I have a Isomac Millenium where the heater will not shut off when it reaches the correct BAR preassure, and runs even when the machine is plugged in, and the power switch is set to off. Once it reaches the 1.4 bar the green ready light turns on, but the red light indicating the heater is operating stays lit, and BAR pressure continues to rise. Any idea what could be wrong?
  • 1,089 Answers
Hi You need to replace the pressurestat. It is bad. 1.4 bar is way to high also. It should be down around 1.1 bar.
Posted on Feb 06, 2010
How can I get proper drivers and Windows Millenium software downloads by machine serial number?
Windows Millenium has not been supported by Microsoft for many years now, and there are no legacy drivers or other downloads available for it.
Best thing you can do is to load Windows 7 or later on the machine (most machines that were capable of running Windows Millenium are also capable of running Windows 7).
May 20, 2015 | E-Machines etower 600is PC Desktop
Isomac Rituale over pressure
Check if the pressure relief valve is working fine, if not you need to replace the valve.
If valve is fine check if there is an obstruction in the lines, this can incrtease the pressure.
If everything else is ok, replace the pump.
Sep 08, 2008 | Isomac Rituale Espresso Machine
Pump running without reason at startup of Isomac Tea
Isomac Teas domestic espresso coffeemaker, which is a well-priced warm change espresso unit perfect for the particular office or home. It has the whole metal physique in addition to all of the energy you have to help make great coffee in your own home.
Apr 08, 2014 | Isomac Tea Espresso Machine
How do I remove the shower and the diffuser on an isomac millenium?
Hi
You need to remove the brew head gasket in order to get the screen out. Then you will see everything else. The brew head gasket holds everything in.
Jan 16, 2011 | Isomac Millenium Espresso Machine
I replaced the water reservoir and the water softener. It did not fill when I turned it on. I tried to run some water by using the coffee lever but no luck. When it got to temperature I heard a pop and...
Hi
I hate to say it but your element has ruptured and needs to be replaced. Notr hard to replace if you know how to get the sides off. You need to take the right side off if your facing the machine. the element screws into the side of the boiler. If you need an element I have one.
Dec 22, 2010 | Isomac Millenium Espresso Machine
Leak around filter
Any leaks aroung the portafilter is usually the brew head gasket. You just need to replace the gasket. The gaskets only last about 1 year so if yours is older that that, it needs to be replaced.
Dec 07, 2010 | Isomac Millenium Espresso Machine
How do i remove a broken gasket ring?
If it is the group gasket, remove the shower and diffuser, then using an ice pick or scratch Awl, insert into gasket and remove, it will come out in pieces.
Jan 20, 2010 | Isomac Millenium Espresso Machine
I have an isomac millenium which stops working after being warmed up for more than 15 minutes. It would have to cool down completely before I could turn it on and get the green light to turn on again....
HI
There are a few things that will cause this.
Your SSR (solid state relay) is bad. Its on the bottom of the machine inside. If you can see a green light on it , its probably OK.
You could have a thermal fuse on the side of the boiler by the heating element that is bad.
You have checked that your water tank switch is working. Push down on the water tanks to see if your lights come on.
Your heating element is bad.
Your Computer is bad.
Nov 09, 2009 | Isomac Millenium Espresso Machine
Isomac expresso machine
We have owned an Isomac Millenium for ~2y.
In the first months, we encountered low water to the brew head, although both the steam and hot water wands had decent pressure and flows.
Adjusting our grind, so that the coffee beans were coarser helped immensely--for awhile.
Then the problem gradually reappeared as an extremely slow brew time. Our machine was still relatively new, so we shipped it back to our place of purchase. It came back working just great and interestingly the filter in the resovoir was now filled with the filtering particulate it did not come with.
I am surmising, that however great the engineering is on the Isomac, manufacturing leaves something to be desired. Do not let your warranty expire. Pay the shipping and fix your otherwise great machine.
Nov 05, 2007 | Isomac Millenium Espresso Machine
Isomac Millenium Espresso Machine Logo
277 people viewed this question
Top Isomac Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Isomac Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
