Question about Canon PIXMA MP830 All-In-One InkJet Printer
Paper jams when it starts printing almost immediately, I can tell its only on one side, sort of a twisting action.
    Guru:
  • 161 Answers
If your printer always have a paper jam..check your adjuster of your paper tray..maybe it is not in proper place...
you can also check if your moving ink..is in proper place...im the one that is moving along inside your printer when it print's the one with the ink...get it??
Posted on Feb 06, 2010
    Scholar:
  • 185 Answers
You have a foreign object in the paper way. Remove the paper and turn in upside down and give it a firm shake.
You should hear the object rattling in it. If it does not fall out. use a small flashlight to locate it and the remove it.
after removing it, give it another shake, and keep removing and shaking until ther is no more rattling.
Then it should work fine.
Every time i print it keeps getting jams
You'll have to open up the printer and remove any paper pieces that are blocking paper delivery. There's usually a panel on the back of the printer that removes easily, maybe with a twist of a lever, and you might look in the front too. I couldn't find a troubleshooter manual online, but you should have one in your documentation; It should tell you where to look for jams.
Dec 05, 2013 | Canon ImageRunner 2270 | IR2270 |
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
Prints one side fine turn paper over to print other side and it twists paper sidways and tears it in half.
Hi. It's hard to say without more details, but two things come up quickly to mind. 1) is the paper only meant to be printed on one side? Some are, and should indicate so (i.e. 'load this side up'). 2) the paper is goofed up (bent, flexed, twisted, loosened up, etc.) by the first printing and therefore is getting jammed.
I'd suggest changing brand of paper and / or be very careful loading, as this seems like a pretty regular paper jam situation.
Aug 06, 2009 | Office Equipment & Supplies
Canon MP470 - Paper starts to feed and twists then jams
i had the same problem, mine went into the printer fine and started to tilt. all i did was check the paper input slot and there was a necklace stuck in it, it was an easy fix after all, just had to pull it out. too bad there are more problems than it is worth tho, right now mine wont feed lol
Nov 11, 2008 | Canon imageCLASS D880 All-In-One Laser...
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
Paper jam
This video explains how to resolve a recurring paper jam on your product. It sounds like the rollers on the rear access door may not be working properly and are making jamming the paper as it starts to feed up into the printer? Check the rollers on your rear access door and see if they have some give in them and roll freely.
Sep 27, 2008 | HP Photosmart C7180 All-In-One InkJet...
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Printer will not allow paper to flow freely; it jams on the left side and prints crooked.
first cancel all the prints going on and switch off and on the printer and keep the paper slowly
Aug 07, 2008 | Canon PIXMA MX310 All-In-One Printer
Paper jam cleared - but still won't work
turn off the printer for a while then back on again, if it still refuse to print, try printing a test page.
Feb 13, 2007 | Canon LBP 800 Laser Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
51 people viewed this question
old marine
old marine
