Question about Boss Music
Can I use a computer hard drive in my Boss Br8 multitrack recorder the zip drive is not reading....something like 20 gig or whatever is in a pentium 3 would this work and if so how do I do it???
  • Boss Master
  • 5,603 Answers
It is not likely the firmware will talk to a hard drive as the interface is different.
Refer to the VSPlanet.com site where some have converted to use SD cards in place of Zip drives.
Posted on Feb 06, 2010
Boss br8. I have no power is there a fuse inside the machine?
There should be a fuse on the power supply board inside the unit. If it is not that then it is most likely the board itself. You can get a replacement at Allied Electronics.
Nov 29, 2014 | Roland Boss BR-800 Digital Recorder
I have a Boss 1180 cd player to record music on. I have recently taken it apart because it needs a new hard drive. I was needing to know what would be a compatible hard drive for a good price. The orginal...
FAT32 is a formatting standard of the disk where 32 bits are used for sector pointers. It is one of the standards and replaced the original FAT16 when larger drives required more sectors than the 65K that the FAT16 provided addressing for. The FAT32 gives one 65K times 65K total... even that is too small for the newer big drives so there are a couple of other standards now to accomodate these newer drives.
The FAT32 is still a current standard. DO NOT buy any USED drives from any source. You might also check TigerDirect.com.
Here is a good article to read:
http://thestudiofiles.com/?p=241
Dec 15, 2010 | Music
Each time I attempt to initialize a zip disk in my Roland BR8...
Probably the drive has gone bad as a first thought... this happens. Possibly the heads got dirty...
Make sure nobody has smoked tobacco around the unit as that is a killer for Zip drives.
Sometimes they have a second level of initializing/formatting. If the BR* has that, try it.
Jan 25, 2010 | Boss Music
Boss BR 8...I insert the 100 mb disk, then asks to initialize..I enter 'yes' then it asks 'sure?' I enter yes then it says 'medium error' then ejects the disk..what's the problem?
If the disk had data put on with a PC you might try deleting all files and folders using the PC before formatting the disk in the BR8.
It is also possible that the media has gone bad.
A final try would be to degauss the disk and try to format on the BR8.
Sep 09, 2009 | Boss Micro BR Digital Recorder
Need Help on a Boss B R 8
I think I solved this problem.
I used a different power adapter and it works now. Try different adapters, I used an old Nintendo one. It is 9V 1.3A, even though the back of the BR-8 says 9V 2A
Jul 18, 2009 | Boss Micro BR Digital Recorder
BR8 Digital recording studio lights up, but it doesn't do anything else
I called Roland at the number that you provided and gave they following proceedure which will re-intialize the BR 1180 and ERASE everything that was created on the HD:
  1. Simultaneously hold down button beneath volume control at track 5 and Undo/Redo button at upper right
  2. Press power button while holding down buttons as above, until test menu comes up
  3. Turn selector dial untill initialize screen shows
  4. Prdess ENTER and initialization will start
  5. Once initialization is completed, power off unit and then power it back-up.
NOTE: This proceedure erases all data!
Apr 16, 2009 | Boss Micro BR Digital Recorder
Boss 1180 Hard Drive Error
Im Sure You Solved This Problem But For Other User Yes There Is A Way To Save Your Data If Your Hard Drive Is Still Operable. You Can Put Your Boss Hard Drive Into Your Computer And Copy Its Contents To Your Computers Hard Drive. Some Say That If The Hard Drive Is Not Operating You Can Put It In A Ziplock And Then Stick It In The Freezer For An Hour Then Attempt To Retrieve Your Info. Remember Always Back Up Your Data On Hard Drive Recorders As They Are Not Fail Safe.
Apr 13, 2009 | Boss Micro BR Digital Recorder
Boss br-8 digital recorder wont load up. powers up but no program
This Sounds Very Bad Do You Have Experience With Taking Apart Computers? If So You May Want To Open Up Your Br-1180 And Remove The Hard Drive And Put It In Your Computer And Copy All The Data Off Of It. I Also Would Recommend Calling Roland They Are The Most Helpful People In The World.
www.Myspace.com/CrossRoadsToNowhere2007
Dec 28, 2008 | Boss Micro BR Digital Recorder
Music Logo
611 people viewed this question
Top Boss Music Experts
Matthew Spark
Matthew Spark
shaun taylor
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Boss Music Expert? Answer questions, earn points and help others
