Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663w TV continued Jumper has been removed, Index delay is 47 but what about the Actuator value? we have put ours on 113 right now! The TV has the very same problem that told us to replace the color wheel in the first place.
3 Suggested Answers
  • 16 Answers
SOURCE: Samsung HLP4663w. After replacing the Ballast,
if the picture is blue green there is a jumper to be removed on the dmd board on connector cn810--the index delay should be between 40 and 50 for optimum color --or adjusted for best flesh tone also in the options the cw setting should be set for cw2
Posted on Feb 06, 2010
Testimonial: "So far I am satisfied with the quickness of the response! Its great to have prompt a reply"
  • 69 Answers
SOURCE: Samsung HLP4663W I have changed Bulb, Ballast,
th dmd pcb can somtimes cost as much as a rebuilt light engine that comes with the dmd pcb colorwheel and dlp chip. look into a rebuilt light engine from tri state modules or pts electronics.
Posted on Feb 07, 2010
Testimonial: "Thank you for your quick response!!"
I changed the color wheel in my HLP6163w. Now the color is off. I looked at the delay index and tried to adjust it but it won't work. The colors are just not right. How do I get the colors right?
Check if instructions with color wheel show a jumper on DMD board for an upgraded bearing-type of color wheel. Jumper hole would be on rear-facing shield of DMD board. (Standard 2-pin jumper used on computer boards.) Probably would have to remove jumper; not insert it.
May 02, 2010 | Samsung HLP6163W 61" Rear Projection...
After replacing the color wheel the picture is mostly blue and sometimes the TV goes to green. Trying to understand jumper cable that may need to be removed, I have the HLP 5663WA. Any help would be...
yes u need to remove this jumper , if u look ur tv from the back the jumper is on the board that is attach to the optical block it is cover by a shield plate if look closer there is a small hole u may need a fine plier to take this jumper out
Apr 13, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I have a HL-P6163W, hooked to dish network hd
Fire the TV Tech! Your problem is the adjustment to the color wheel timing. To correct this: With TV OFF -> on remote, press MUTE, 1, 8, 2, POWER. The TV will come up in service mode: ( Left / Right arrow keys for item selection, Up / Down to change values, Menu to return to previous menu, Power to exit Service Mode)
Enter the submenu of item 1. DDP1011. Now, adjust item 4. INDEX DELAY to correct the "clay facing" problem you are having . Default value is 47.
You should have a "problem" image paused to check you work if possible. I hope this was of some assistance, best wishes.
Apr 12, 2010 | Samsung HL-P6163W 61" TV
Samsung HLP4663W I have changed Bulb, Ballast, and Color Wheel, Yes, removed the Jumper and set to CW2 too!(color wheel had no sticker with CCA Values or Actuator or Index Delay Values on it) I set the...
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663w. After replacing the Ballast, Bulb and Color Wheel (color wheel came without the CCA values and the Actuator and Index delay values) we still have the same color and picture problems. Do...
Replaced my Samsung HLP4663W color wheel and the
The jumper if it has it usually causes the color to look funny blue instead of normal.
It is located on the DMD board--the metal box on the light engine where the two plugs from the color wheel are.
It will be in a small opening on the metal shield that covers it--small and rectangular in shape--it has a small metal tab across it--it jumps two pins--
if it is there with a hemostat or small needle nose pliers pull it carefully out and see what you have--The CCA adjustments are done in the TECH MENU--look to see first if the jumper is there and remove it.
A lot of places that sell the wheel do not tell people about this.
If this has helped you rate this solution, as I do this here for FREE.
sd tech
Nov 11, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W color wheel replacement
yes its true grt your self a pair of needel nose pliers and pull that jumper.
I had a tv set in my shop for weeks till i lerend that one
wat it was is that the new color weel motors are air cor and spin faster that the originals, so pull the black jumper it looks like a small hard drive just remove it
your set will auto ajust.
ther are sum small settings to add in the service menue to fine tune it.
but first pull that jumper..
seting can be found on google... i think i found it on tech assist.
and enterd model number.
Jan 12, 2009 | Samsung DLP HL-P5663W 56" TV
BP9600674A
The jumper that you need to remove is a small usually black block of plastic approx 1/4" in across and 1/8" thick located near the center of the shiny silver colored apparatus into which the color wheel is plugged. Mine had a label that read FDB Bearing Color Wheel, BP67-00099A and two illustrations indicating open and shorted conditions. The label was just over the jumper. I pulled it out with needle nose pliers and the problem was solved. GndLoop
Mar 18, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
When I removed the jumper wire the screen color problems I experienced after changing the color wheel were fixed completely. I did not need to reset the CCA values (which came with my color wheel, on a separate sticker). If you have a black bracket blocking access to the jumper wire, as I did, you can access the jumper wire by removing the fan shown just to the left of the yellow and white sticker; there are two screws attaching the fan to the chassis below it. Next, remove the two screws that hold the silver clamshell (the housing for the circuit board) halves together. These screws are right behind where the fan just was, on either side of the protruding fins. They each have a spring under the screw head. You can then pull the visible half of the silver housing forward (with the bracket attached). You will then have access to the entire circuit board. Look for CN810 - it is located right behind where that bracket just was when it was all put together. Pull the tiny black plastic part (that has the jumper wire) off of the pins. Then reassemble the housing and put the fan back on.
Jan 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
Jerry Greenberg
Jerry Greenberg
