Question about Dishwashers
How to replacement the upper dish rack on Kenmore dishwasher
I have a upper dishrack replacement for my Kenmore Model 665.15831791 dishwasher. How do I remove the old rack and replace the new?
  • Anonymous Mar 20, 2014
    have new part w103503776 but don't know how to remove the old one
    Sergeant:
    Champion:
  • 204 Answers
On the front end of the rails, there should be plastic or rubber stoppers. Remove these and the rack should roll right off as if youre pulling it out to load it.
Posted on Feb 06, 2010
Top dish rack dishes don't get clean model 8575637
Most dishwashers have a rotating spray bar underneath the upper rack. Over time bits of food can clog up the holes and then dishes won't get clean in the upper rack. Check to make sure all the holes in the spray bar are clear and that it is rotating freely.
Mar 22, 2017 | Dishwashers
I'm looking for a dishrack that has room for all my dishes and will drain well (not just make the other dishes all wet).
i like the first one from this top ten list the best. http://www.realsimple.com/home-organizing/organizing/kitchen/dish-rack-00100000076215/index.html
Jan 14, 2013 | Home
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
I need a dishrack for a whirlpool dishwasher model #DU920PWKBO
You didn't specify which one you need so
LOWER RACK PART NUMBER 8193795
UPPER RACK PART NUMBER 8519572
They can be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
assuredparts.com
apdepot.com
appliancepartspros.com
Gene
Aug 09, 2011 | Whirlpool Dryers
Dry time for touch-up paint 676453
I would let it dry for 24 hours before using the dish racks.If you are going to leave the racks inside the dishwasher after you paint them be sure to leave the door open to help the paint dry.
Jul 25, 2011 | Whirlpool 676453 DISHRACK REPAIR
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
The upper sprayarm flows water but does not turn. Therefore dishes in upper rack are not geting cleaned.
i have a kenmore elite dishwasher model 665.16059400, i need a lower spray arm nut, nobody can find this part, i've been to sears and also to their on line parts department 3 times and have come up empty, the last time i was assured that the nut would be included with a new spray arm if i ordered one, it was not,i know the spray arm was made by whirlpool, is there anyone out there who knows the solution to this simple problem? does whirlpool have a cross referance model number i can use to find this part
Apr 29, 2009 | Dishwashers
Kenmore 665.16389300
Test by pulling out the lower rack and run an upper load, it may just be a loading issue. Some washers are better than others, in that they have stronger moters and impelors than others. The impellor may have something like a fork, knife, or broken glass in it.
Jun 17, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Dishwashers Logo
284 people viewed this question
Top Dishwashers Experts
Owen Barnes
