Question about RCA DRC277 DVD Player
Why won't my TV pick up my DVD connection? The player works fine, but the TV isn't showing the picture. What do I do?
  • RCA Master
  • 12,061 Answers
Are you sure you are selecting the Audio Visual Input? The wire are color to color Yellow to Yellow, Red to Red, White to White. Ensure you have it in the correct Video IN and Audio IN and have selected and the correct AV input on the TV.
Posted on Feb 06, 2010
Proline LVD TV and DVD player problem. Hi, I can't get a picture using the RF option. I'm not sure what input I should select for this but I've tried them all and no joy in seeing the sky picture from the...
Hi Greg, i think your missing something simple.
Pick a channel number you want the Sky on, then in the tv set up
manually tune that channel to 68, or if it's showing lots of numbers for the frequency then just search towards the end and it should pick up. On the Sky box leave a menu showing so it's easier to spot when it gets to picking it up.
Nov 10, 2014 | Televison & Video
My LCD Sanyo tv won't show picture and the green
PLEASE CHECK CABAL LINE FIST. SEE THE TV BACK SIDE AND ADJUST UR CABAL JACK.OR HAVE ANY DVD PLAYER PLEASE ADJUST UR DVD JACK SEE UR TV PICTURE.IF SHOW UR PROBLEM SOLVE OR NOT SHOW UR TV PANEL PROBLEM.
Dec 27, 2012 | Televison & Video
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
I own an iview 2600hd dvd player and im trying to hook it up to my sony trinitron tv...however, no matter how i switch my cables, the dvd player just won't show any picture or audio on my tv...and when...
Try new cables. RCA cables have a tendency to have bad connections internally. Also, triple check that you're on the right input and the wires are properly connected to the DVD player. If all that fails, try the DVD player on a different T.V. and something that uses RCA cables on your T.V, such as a cable box to make sure the input jacks on the T.V. aren't bad, and the DVD player isn't bad.
Through out all of this troubleshooting, you should manage to get the DVD player hooked up.
Jun 20, 2011 | Televison & Video
VIZIO P50HDTV10A PICUTURE FLICKERS IN AND OUT CONTINIOUSLY WHILE WATCHING TV. PICTURE DOES NOT FLICKER IF WATCHING VIDEOS.
HI, you can do these troubleshooting steps and get back to me..
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jun 17, 2011 | Televison & Video
DVD not showing a clear picture
test test test 17:05
danke bitte
do not answer test test
sorry
Jul 04, 2009 | Televison & Video
No picture, but can hear sound
hold down the stop button for 5 sec on your dvd player not the one on the remote control
Check your connections. Make sure they are hooked up correctly(ie yellow to yellow. Check both the connectoins on the dvd player and the tv.
Feb 11, 2008 | Cyberhome CH-DVD 300 DVD Player
No picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Dec 06, 2007 | Panasonic TH-42PX60U Television
RCA DRC277 DVD Player Logo
258 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
