Question about Mitsubishi WS-65411 65" Rear Projection Television
I have a Mitsubishi WS-65411. I click on the remote control to turn on tv, after about 15 clicks will turn on but only for a few minutes. I tried holding the Menu and Input button but no avail. Please help.
  • 10,515 Answers
Before you Proceed, Disconnect the Power Supply, Unplug the Cord and then try to plug in after few minutes, say 30 minutes. If the Problem persists, more likely it's a Faulty Power Supply Board.
You need to have some electronic Experience to Open the TV and then you need to locate the Board. Once you find the Board, you need to pull the wires and try to Look for Swelled / Bulged / Leaked Capacitor. You need to go to Radio Shack or Order Online and then replace that. Once replaced, that would fix the issue. Usually, Bad Caps do have Ammonia kind of odor.
You could see the Service Manual on the below link :-
http://www.scribd.com/doc/10795045/Service-Manual-Mitsubishi-Projection-TV-Chassis-V20ACC
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 06, 2010
Why doesn't TV stay powered on?
Have you tried to download the instruction manual from the Internet?
Feb 04, 2015 | Mitsubishi WS-65411 65" Rear Projection...
I need the 3-digit remote control code for Pyle Pro P1001AT amplifier so I can program it into my Mitsubishi WS-65411 TV Remote.
033,028,019,092,088,000 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 10, 2013 | Televison & Video
Only turns on with remote and won't stay on
Power button on the television itself may be stuck - go to the unit and press the power button se if it engages. If it depresses and sticks there is your issue - if it does not check the remote take out the batteries and unscrew the unit take the rubber pad out of the casing and spray out with canned air. If that doesn't do it - try unplug the tv from the wall for 1 minute or 2 and replug-in and see if the problem persist if so you will need to contact a tv repair shop but it sounds like the button on the tv needs to be cleaned because something is holding the power position in a spot to turn the unit off
Jan 14, 2013 | Mitsubishi WS-65411 65" Rear Projection...
Power will not stay on
soumds like the on off switch is faulty best call a repair man
Jun 10, 2012 | Mitsubishi WS-65411 65" Rear Projection...
Tv has worked for ever with the remote now remote has failed and the on off swutch doesnt work to turn it on and off How can I program another remote if I can turn it on?
First, check to make sure the front keyboard is not locked out. Press and hold the menu key for 10 seconds then release. If it was locked out, then front panel buttons should work. If no change, you likely have a problem with one of the ten contact switches on that panel. Remove the front speaker grill by pulling it off, then trace the wires from the front control panel (you may need to remove the cover off the front of TV). Unplug the wires to the front panel and try by Remote control. If the remote works, you can purchase ten tact switches and install or just leave the wires unplugged and use it like that.
Bill W
integrityhomeworx.com
Mar 13, 2011 | Mitsubishi WS-65411 65" Rear Projection...
Power turns off by itself once in a while. i turn
There can be several causes for this, few of which you can do anything about. However, a few things to try.
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
Feb 25, 2010 | Mitsubishi WS-65311 65" Rear Projection...
65 mitsubishi model ws 65411 trying to use blue ray
The Tv can only handle a 1080i imput you need to go to the settings on the blue ray player and turn off the HDMI and select component with an output of 1080i. The TV will not accept a 1080p signal
Apr 26, 2007 | Mitsubishi WS-65411 65" Rear Projection...
Mitsubishi WS-65411 65" Rear Projection Television Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
