Question about Acer Extensa 5420-5687 Notebook
Lost full strength to our wireless network. i am
Lost full strength to our wireless network. i am sitting right next to the router and getting a poor connection
  • 153 Answers
Check with other router signels
Posted on Feb 06, 2010
Tablet can not connect to wi-fi
Try "forget network" and reconnecting.
Dec 06, 2013 | Samsung Galaxy Note 10.1"
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Restar
If by resetting you mean the wireless connection keeps dropping and reestablishing then you must likely have poor signal strength to the wireless router. The strength of the wireless signal can be greatly diminished by walls and other objects in the way of the wireless router. Best advice if your fairly close (less than 20 ft) from the router would be to invest in a wireless N router, you will get a much better signal.
Feb 03, 2012 | Computers & Internet
I have a sony vaio notebook with windows7 we have wireless at home and my kids laptops get excellent wireless connection - mine is always fair or poor -unless sitting next to the router What can I do to...
If your kids laptops are getting good signal strength then, its the problem with your laptop. You nmay have to upgrade your wireless adapter to N standard. The one which you have might be a b/g standard adapter. Check with your sony to upgrade the wireless adapter.
Thanks & Regards,
Prema.
Jan 17, 2011 | Sony VAIO PCWA-C300S 802.11g/b Wireless...
Poor wifi performance
Doesn't matter,those signals can't get up to your study cause of the basement. when outside it's fine. try putting the router at a higher end, like on a stool or try the highest point in the basement. Or try getting some high gain antennas that will boost the signal.
Mar 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I can not connect to the internet but it still has strong signal strength. It will only connect to the internet when I am right next to the router. Why is this happening and what should I do?
One thing to keep in mind is that there are several different router/adapter models, types, and signal strengths. If your house/apartment is older, it may have poor wire insulation. This would create large electromagnetic interference for your wireless signal. This can also happen with large appliances such as a refridgerator or generator. Wireless also has diminished returns when passing through concrete or walls made with thick/heavy material.
You may try moving the router to a different, more central portion of your residence to see if the signal improves in all areas. Try to determine which direction, from the router, it tends to have the lowest signal strength and determine what may be causing the loss of signal strength.
Aside from that, if possible test with a different router/wireless adapter. You can accomplish this by having a friend visit you with their laptop or visiting a friend's wireless network and seeing if you have the same problem. The later of that advice applies to wireless hot spots like Starbucks or McDonalds/Dairy Queen.
Mar 03, 2009 | Encore ENUWI-G2 802.11G WIRELESS USB 2.0...
Range is very poor
You need to change the wireless channel of the router. Access the router's setup page through http://192.168.1.1, no username, password is admin. Go to wireless tab, Select Manual Setup, change the Radio band from auto to Wide Range. Also change the Wireless network name to a different name then click on save settings at the bottom. Power cycle the router, unplug it for about 30 sec then plug it back in.
Jan 19, 2009 | Linksys Wireless-G Broadband Router
Poor signal strength on wireless router? ?
k login to the w/l router and change the channels to 11>or 1 use always use these only and delete all teh temp files and delete cookies and clear history and check with antena which is straight>and reboot the router and laptop>and rate me solved if its help full
Oct 30, 2007 | Belkin (F5D6230-3) Wireless Router
have a go at changing the wireless channel within your router there may be some interfearence generated by your pc that is affecting its signal strength
Oct 29, 2007 | Computers & Internet
Acer Extensa 5420-5687 Notebook Logo
81 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
