Question about Canon PowerShot S2 IS Digital Camera
Canon SX100 IS
When i turn my camera on everything on the screen turn upside down how can i fix this problem
  • 71 Answers
Hello Dear,
In the Menu there is a settings option under this heading the last option avalible is "Reset" press set or ok amd your problem will be resolved, you can also mail me back if this does not resolves your problem with more clearifications.
Regards,
Manoj Joseph
+91 9352008418
Posted on Jun 11, 2008
My Canon Camera
This camera needs to be sent to a Canon digital camera repairer.
Apr 28, 2013 | Canon PowerShot SX100 IS Digital Camera
When i turn on my camera, it registers a message on camera screen "lens error, restart camera" and then it automatically turns off.
Hi there!
If the camera is still under warranty, I suggest to bring it to your Canon so you can determine if the warranty will cover the repair. If not, try this DIY method to fix the problem.
Hope this helps.
May 19, 2011 | Canon PowerShot SX100 IS Digital Camera
Camera says card is locked canon powershot sx100
"Card is locked" usually means that the little write protect switch on an SD card has been set to stop the card being written to. Seems unlikely that it would happen to two cards in a row, but it is worth checking this.
Nov 05, 2010 | Canon PowerShot SX100 IS Digital Camera
Hi, this is a frustioning question. How do you open the battery door. I have an instrucation guide, for I can't figutre it out. Beverly
Hold the camera upside down lens to the right. Slide the battery door release button to the right and at the same time slide the battery door away from you.
Aug 29, 2010 | Canon PowerShot SX100 IS Digital Camera
My Canon Power Shot SX100 IS says lens error. restart camera. Help
Aug 24, 2009 | Canon PowerShot SX100 IS Digital Camera
Canon SC100 Lens Error
I have a 3 year old Canon PowerShot SX100 IS. While testing an external battery power supply I built, the external power connector pulled out while the lens barrel was extending just after I turned on the camera. Power to the camera was lost before the lens barrel fully extended and wouldn't reset when I repowered the camera. The dreaded error message "Lens error, restart camera" appeared and the camera shut down. I restarted the camera over and over and over again but the lens wouldn't reset. I was extremely lucky to find the information here and read various fixes. I didn't want to take the camera apart so I tried various fixes others have successfully used. I first tried smacking the bottom of the camera hard with the palm of my hand just after pushing the on/off button but that didn't work. The one which worked was smacking the camera on the side immediately after I pushed the on/off button. I smacked it quite hard twice with the palm of my hand then, suddenly, the lens barrel began to move and the lens reset itself back to its starting position. Thanks to everyone who has posted here!
Apr 07, 2009 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon showing black screen
needs to go in to a camera shop for repair, either the shutter is broken in the lens or the CCD is bad...could be more than that but, It would have to get disassembled to determine that. I work on Olympus cameras and have found that sometines it's easier to let someone with a box of spare parts fix it...
Jul 26, 2008 | Canon PowerShot SX100 IS Digital Camera
Cannon SX100 Display is reversed/backwards
think the only way to fix that is service, you have a year warranty provided the camera wasn't dropped any to cause it
May 26, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
85 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
