Question about Tomtom GO 300 GPS Receiver
Need the tomtom memory card program download - Tomtom GO 300 GPS Receiver
Can you up date tomtom300?
Posted on Feb 20, 2010
When turn On can get the screen showing the GPS connected to Computer when not connected ,On Battery only, get red cross flashing
If your TomTom shows a red cross, it means the device is not able to load the software to be able to operate. Some devices have this software on a SD-card, some have it stored on an internal memory.
If there was a SD-card in your TomTom, I would suggest to put it back. If there is a empty SD-slot on your device, it could be you lost your SD-card, but some TomTom devices have an internal memory AND a SD-slot for memory extension, so if you have an empty cardslot it doesn't necessarily mean there has to be a card in it.
When you never saw a SD-card, probably some data went corrupt on the internal memory. When you have a SD-card, probably some data got corrupted on the SD-card.
To repair the software, you need to connect your GPS to your PC or Mac with a USB cable.
You also need the program TomTom HOME. You can download it for free on the TomTom website.
With TomTom HOME you can update the operating system of your device for free (map updates are nor free).
Try updating, and see if your device works again.
If this doesn't work, post it here.
May 14, 2015 | Tomtom GPS
Download maps to SD but TomTom won't read them
The OneXL can't read form internal memory and SD card at the same time.. much like a floppy disk on a computer. If it shall boot from SD card, it need the software installed as well...
May 05, 2009 | Tomtom ONE XL GPS
Tomtom One 3rd Edition Map downloads
Some versions of the TomTom ONE 3rd Edition have limited internal memory(no memory card slot).
connect your device to TomTom Home to check how much memory you have available and check the map is not too big for the internal memory
Mar 24, 2009 | Tomtom ONE 3rd Edition GPS
Download problems with my tomtom one
I have a Tom Tom go 300 the existing memory card is only 128 MB. so i purchased a new 2GB sd memory card that is compatable with my device. I followed the instructions on Tom Tom Home which tells you to back up your TT take out the memory, install the new memory card and then restore your device, the problem is that it won't restore the information from my computer back onto the new 2GB memory card.
Mar 16, 2009 | Tomtom One Europe v2 GPS Receiver
Tom tom Western european map
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Feb 24, 2009 | Tomtom One XL GPS Receiver
How do i install my own maps into my tomtom go 720
The tomtom comes with a small memory card. you go to www.tomtom.com enter your tomtom card in the computer and download the maps to your memory card from the tomtom website.
Artgirl
Jul 18, 2008 | Tomtom GPS
TomTom One Europe
What is happening is your map updates are being copied onto your memory card without overwriting the old maps hence you are running out of memory.
In the tomtom home browser you should be able to delete your old map before installing the new one. Make sure you have a back up of the map card before you try this though so you can reinstall if something goes wrong.
Also have you replaced the voice prompts on your tomtom? The voice files take up a lot of memory so if you have put new ones one without removing the old ones you will be wasting memory.
There is one window in TThome that lists eveything installed on yuor card so have a good look at this and see what you can get rid of.
Oct 30, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom 1
You cannot use a sd card from another tomtom. The sd card is coded for each individual device. About the only thing you can do is to purchase a 1 gb card (no larger because it won't be supported). Insert the blank card into your unit and connect it to your pc. Go to my computer and see which drive the tt is. format the card and then open tomtom home. This will load your operating system back onto your card. I don't know if you can download a free map or not. Check the tomtom forums for more information concerning maps.
Hope this helps
Oct 13, 2007 | Tomtom ONE GPS Receiver
Tomtom One
If you have the programs downloaded from tomtom home then you need to copy them to the sd card that you purchased. In the home program you can choose to install the programs and map to the sd card. It takes a bit of a search to get the tomtom home program understood. The credit card with the codes is an authorization code for the program.
May 17, 2007 | Tomtom 1D00.081 GPS Receiver
Speed Cameras
You may have not written the entire program to the SD card. If you saved the program prior to the upgrade, start tomtom home program and reinstall the program. then upgrade again. The tomtom home program is not as user friendly as you would hope. Also turn the unit off, take out the card and then reinsert and turn the unit on again.
Mar 13, 2007 | Tomtom ONE GPS Receiver
Tomtom GO 300 GPS Receiver Logo
206 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
