Question about Garden
My Ryobi string trimmer has seen a lot of use over the years. Over the last year the switch began to work only intermittently, and finally stopped working. I took it to the closest repair center (150 miles away), and although they are not a Ryobi repair center, they thought they had a switch that might work. A few hours later I retrieved it--supposedly repaired--and drove it home, the return 150 miles. When I went to use it, again it works only intermittenty. I press it and press it and press it, and when it finally starts, I try to do as much as possible before releasing the switch because I know it'll take forever to start it again. Is this because: A. the off-brand switch just won't work, or B. there is another problem . . . something about the motor, perhaps. I've really liked this trimmer--it's not too heavy, it's easy to use, and does a good job on the 40-odd types of native grasses around my house in the country. As a woman, I am not willing to mess with a gas-powered trimmer, but I need more power and durability than those piddly little weed-eaters people use on suburban lawns.
  • vjlowe Feb 08, 2010
    Apparently Ryobi no longer makes an electric trimmer that ues a cord, as my model does not get any matches in their parts department. So clearly I am going to have to buy a new trimmer. I wonder if you could give me some advice on a new one? I definitely don't want a gas-powered trimmer because of the noise, the mess and the fire danger where I live. I don't want a Black & Decker because it strikes me that the brand is like the Weedeater brand--more for suburban homeowners than people who have tough, tall grass to cut. I read an old Consurmer Reports forum where the guys (all guys) were saying there just wasn't anything electric that could cut grass and weeds, but my Ryobi did a great job for years. All I am seeing in the way of choices is the Stihl FSE 60 Electric Trimmer or the
    Ryobi LITHIUM 18V 12" CORDLESS STRING TRIMMER model # P2002. This Ryobi cuts only a 12 " diameter swath with .065" single line--which again says "suburban lawn" as opposed to my old corded model that cut 15" in diameter with .080 double line. Also the new battery powered Ryobi line is auto feed, which I can't really see working well with all the rocks and things that can break line around here. So it seems my only option really is the Stihl FSE 60, which isn't adjustable for height, weighs 8.8 lbs. and has only a 14" swath . . . but at least it still has a bump knob. Is there anything good out there I don't know about?
  • vjlowe Feb 12, 2010
    Not yet been replaced, but will be when I get somewhere to purchase the Stihl. It's a shame Ryobi stopped making electric trimmers--the cord is not that big a hassle . . . 2 or 3 together will get you a long way. And it's not just men that use these trimmers--women do, too. I imagine lots ofwomen like me don't like those noisy smelly little engines. I think those are a "guy thing". Thank you, Mr. yard guru.
  • 8,197 Answers
You can have 2 things wrong with the trimmer still.
1. is yes wrong switch.
2. is the brushes in the motor need to be replaced.
You can find a service center on link below or you can order parts on the link below by contacting customer service. If you contact customer service they might give you instructions on how to change the parts.
http://www.ryobitools.com/support/service_center_locators
Posted on Feb 06, 2010
Why does my ryobi 18v hybrid string trimmer work well on electric but slowly on battery?
How old is your battery? Don't expect a battery to last longer than a couple of years. Try this before going for another battery. Put the battery in you freezer for 3 days. Take it out and let it thaw for 4 days. Charge it and see if there is any new life in it. If not, it's battery time.
Apr 09, 2017 | Ryobi Garden
How to install string for ryobi 50 volt string trimmer
Line Trimmer Line Replacement of a Ryobi One+ 2013 ...
? 2:33
www.youtube.com/watch?v=8jEER8lHUQk
Feb 22, 2013 - Uploaded by TheLegoCityBoys How to replace line in a garden Line Trimmer. ... Ryobi 40-VoltLithium-Ion Cordless String Trimmer RY40210 - Real World Review & How To ...
Aug 08, 2015 | Ryobi Garden
Why is my ryobi 18 volt trimmer smoking? I have had this 2.5 years and using it on lawn edges only.
The motor is failing. Most likely the brushes have failed, but this is all sealed and they cannot be replaced alone.
Jun 10, 2014 | Ryobi 18 Volt 18v Cordless String Trimmer...
I have a 2 year old Ryobi RY34440 String trimmer, 30cc. Last year worked fine, this year pull cord is so easy to pull it doesn't even turn engine over. Is is the spark plug?
Either the pull starter is not pulling or you are not getting compression. To check you need to check the spark plug is still snug. If so, remove the plug and put a drinking straw in the hole to touch the piston. Slowly pull the starter to see if the piston is moving. If the piston is moving and the plug was snug then you are losing compression somewhere, like a head gasket. If not moving then the problem most likely is in the starter, and disassembly required to investigate.
If really helpful, please rate.
Jul 12, 2011 | Ryobi Garden
Bought new Ryobi P2002P from local home improvement chain, less than 2 wks ago; after assembly and charging battery, I found the .065 string equipped with the string trimmer kept breaking when trying to...
My first choice for a repair is to return this unit to the store, so that they will know that what they are selling is not working.
My second choice is to have you put a good quality line on this trimmer. Ryobi has tried to save a few cents by using a very lightweight line. I have not had a lot of personal experience with battery operated trimmers, but my impression is that they are very light-weight and take significantly more time and effort to achieve the same result as their electric or gasoline counterparts.
Check your owners manual to see if you can use a size .080" trimmer line. Stay with round line. The square or star shaped lines tend to stick to themselves and don't feed well. If you have to stay with the .065" line, find your local lawnmower repair shop and see if they sell a higher quality line.
Good luck.
Oct 21, 2010 | Garden
Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
May 25, 2009 | Ryobi Garden
Engine runs but no power to the head
It could be simple. Sounds like the drive cable came loose or broke. You could get an estimate from a repair shop -- probably not terribly expensive.
May 08, 2009 | Garden
3 year old ryobi gas trimmer won't start...didn't winterize. I follow the start-up directions and it won't turn-over.
This could be caused by tons of problems. I'm going to assume you've checked the spark at the plug first. If not then you'll want to pull the plug out, leave connected to the wire and check to see if there's a blue spark when you pull the starter string. When my trimmer finally wouldn't start (or keep running) I found there were small cracks in the fuel lines. It was causing problems with the prime (for starting) and then with the running. My engine wasn't leaking fuel so it was hard to find.
May 02, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
