Question about Kenmore 63942 Dryer
I'm changing to motor. Everything is un hooked but I can't get the rear fan wheel off the shaft. I see it has a backwards thread. But I can't get it to break loose. Any ideas?
  • 311 Answers
Sometimes the nut will freeze on the motor especially if the motor was overheating and shutting down on its overload. The only trick I have found to break the blower wheel loose as applying any type of rust buster or bolt bolt penetrator on the backside of the blower wheel. Let it sit for a few minutes and get a 1in drive socket with an extension on it and put it directly in the center of the blower wheel. (it has a 1in drive in the center) Then grab the motor pulley from the back with a wrench or channel locks and try to break it loose with swift jerks on the motor pulley while holding the blower wheel in place with the ratchet. You will want to put the motor clamps back on to help hold the motor in place. Remember it is a reverse thread.
Swift jerks usually work better to break it loose than just increasing pressure. (if you dont have a 1in drive anything you can fit into the blower wheel to hold it in place will work).
If you still have no luck at breaking it loose you can always take a flathead screwdriver and a hammer and chisel around the blower wheel and break it off. The only downfall to this method is you have to buy a new blower wheel Part# 697772 for about 40 bucks.
Hope this helped _MJ_
Posted on Feb 06, 2010
  • Matt Ace Appliance Feb 06, 2010
    You could also try just placing channel locks on the motor to hold it in place and grabbing the fins on the blower wheel with your hands and **** it in a counter clockwise motion. (Be sure to wear gloves because if it breaks loose you will cut your hand on the blower housing its sharp.)
    Let me know how it goes _MJ_
    Correction since its a reverse thread I believe it would be CLOCKWISE that you will turn the blower wheel.
How does fan attach to shaft of motor?
mostly the center section is like a big knob with a left hand thread
turning it clockwise undoes it and the fan section just pulls of the motor shaft
Dec 19, 2015 | Dryers
How do I remove the impeller C105-238P
Sta-Rite pump. Possibly deluxe version? If so, has a securing screw in impeller. This has backwards threads! Remove first, then secure shaft from spinning, use a flat blade screw driver, or 7/16" open end wrench. See pics below, remove back end cover from motor, to expose.
25467099-ljfmxq21ny5mtdwz0zq3xz55-4-2.jpg once shaft secured, un thread impeller, normal direction, counter clockwise. Remember, "Lefty loosey, Righty tighty". Good luck.
Feb 22, 2015 | Pool & Spa
Remove impeller pool pump
remove band clamp remove motor undo cover over impeller hold back of motor shaft unscrew holddown screw backwards thread then un screw impeller regular threads
Aug 31, 2013 | Sta Rite Pool & Spa
Motor heats up and stops running how do remove
The blower fan on this model has reverse threads where it screws onto the motor shaft. At the small space between the motor and the rear wall of dryer you will see that the blower wheel has a square neck that will allow you to hold it stationary with a large crescent wrench. while holding the blower grip the pulley on the front of the motor with another wrench (or channel locks) and turn the motor shaft clockwise to break the blower loose. Sometimes a quick motion is better to free it as it may be on the motor threads pretty tight.
Good luck on this!
Jul 11, 2010 | Whirlpool LER7646E Dryer
The blower fan is lose how do you tighten it up . Whirlpool Duet Dryer
Use a 3/4' wrench on the blower wheel and a 7/16 wrench on the front shaft of the motor. The threads on the rear shaft are left hand threads so make sure you turn the shaft in the proper direction.check the wheel for cracks,usually if they are loose they're damaged,
Dec 18, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Fan is spinning opposite way
there should be like a switch to change direction of fan , if not then you need to change the wire connection , try that , AJ
Aug 13, 2009 | Ellington ROC52ALUM3LKRCR2 Rocket Ceiling...
Machine jammed wheel will not turn needle will not move
Thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands
May 17, 2009 | Brother CS-8060 Computerized Sewing...
Advice on how to get fan off motor shaft on Kitchen Aid Gas Dryer
no special tool, but it is reverse threaded!i usually place a vice grip over the plastic portion of the fan and with a monkey wrench onthe motor pulley im able to break the connection free, REVERSED THREADS gets me every time!
Mar 02, 2009 | KitchenAid Dryers
Tring to get the fan off of the motor on whirlpool dryer
nothing,,you should have keep motor clipped down,,and first remove blower wheel its just screwed on the front side of motor,,put motor back hold the end of motor with wrench,,than turn blower wheel..onthejob
Jan 24, 2009 | Whirlpool LER4634J Electric Dryer
Motor replacement
there is a half in square drive recess in blower wheel insert half in drive into it ..usually a 7/16 open end wrench will hold motor shaft but if not use adjutable wrench to hold motor shaft at belt end turn blower clockwise ..if still can get loose use service tech method chisel and hammer ..if motor has overheated the heat will almost weld blower wheel to motor shaft ..by the way some parts houses may sell the switch as a separate part
Nov 24, 2008 | Kenmore 82822 Electric Dryer
Kenmore 63942 Dryer Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
