Image is harp in center and lburred on both sides.
Image is sharp in center and blurred on both sides. The image appears to be bowed. there is a slight color halo around words and the left side is worse. I adjusted color projector tubes and it helped some.
  • 8,457 Answers
Readjust ur tube back to the original position.Ur convergence is dead,Must know to solders?Replaced the 2 convergence ICS and all it resistors.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Posted on Feb 06, 2010
Canon 1d mark 4 camera viewfinder problem
Adjust the viewfinder diopter to match your eye. Remove the rubber eyecup by grasping both sides and sliding it up. Turn the little knob to the left of the viewfinder until the focus points or center metering circle appear sharp. Replace the eyecup.
Mar 16, 2013 | Cameras
I have a blurry image distortion in the center of the picture only- everything else looks fine- a solution to my problem?
is the central of lcd divice bumped ?
1-are your lcd device show the correct image without any blur before taking the image ?
2- or this blur shown after taking the picture ?
for the first : your device lens should be clean through inner side.
for the second : the lcd should be checked , since the center of lcd may be bumped.
please let me know your checking result.
good luck
gorbesia
Jun 14, 2011 | Nikon Coolpix 4600 Digital Camera
Photos are blurred.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
Sep 16, 2010 | Cameras
I bought the 10x25 camera binoculars and only one lens will focus using the center dial. Its almost like the other one needs to be focused at the eye piece itself. The pictures are not clear and are...
It is common for binoculars to have one independently focusable eyepiece.  If one eyepiece can be rotated, then that is the case.
If that is the case, focus through the one that DOES NOT rotate using the center control until you get a sharp image on that side.  Then rotate the eyepiece on the blurry side until the blurry side is sharp.  If you succeed at this, from henceforth the center control will focus both eyes adequately
Aug 11, 2010 | Sharper Image Optics
MY CAMERA TAKES PHOTOS THAT APPEARS SHARP ON THE LCD BUT BLURRED AND DISFOCUSED AFTER DOWNLOAD.....
Your LCD is only a small preview screen. I have on many occasions tested a camera and viewed on the screen. When you view the image on a computer it is enlarged to a much larger image. If your pictures appear out of focus you may have a bad lens. Set your camera to the highest mega pixel rate and retake some test images. If these are blurred you have a bad lens.
Jul 02, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Image Distorted
This is a classic convergence problem. Please confirm that your model is 51H84 and whether or not you intend to repair this yourself. You will need to know how to solder. If you wish to attempt the repair, confirm the model and update this and I'll provide you with details and instructions.
Dan
Oct 02, 2008 | Toshiba 51H84 51" Rear Projection...
Pictures appear to be darker than original in print outs.
You can make several adjustments to improve your images such as lightening dark areas, changing the exposure, sharpening blurred edges, and changing the brightness and contrast.
  • Exposure adjusts the overall intensity of light in an image.
  • Adaptive Lighting improves only the dark areas in an image without affecting the bright areas.
  • Brightness adjusts the amount of light in colors ranging from light to dark.
  • Contrast adjusts the difference in brightness between light and dark areas of an image.
  • Sharpness helps define edges and the smoothness of texture in an image. Use this tool to make a blurred image appear more focused.
Adjusting the image Follow the steps below to make adjustments:
  1. Click the View tab and select the image you want to edit by either clicking the image, or by clicking the small box at the bottom left corner of the image. Figure 1: Select the image c00603524.gif
  2. Click the Edit tab and then click the Advanced tab.
  3. On the Advanced tools tab, click Adjust Image .
  4. Select an adjustment from the list on the left. Figure 2: Adjusting the brightness c00603525.gif
    • The Exposure adjustment is automatically applied when the Adjust Image tool opens. Eight variations of the image are displayed on the left. The current image is displayed in the center. Each image represents a different level of adjustment. When you move the pointer over any of the images on the left, a large version of the image is displayed. Use Preferences to turn this large image preview on or off and to set the timing for the display.
    • If you want to use a different adjustment tool, select Adaptive Lighting , Brightness , Contrast , or Sharpness from the list.
  5. Select one of the images on the left.
  6. Do one of the following:
    • Click Accept to accept all changes and exit from the Color Toolkit.
    • Click Cancel to discard all changes and exit from the Color Toolkit.
  7. If you have finished modifying the image, do one of the following to save your changes:
    • Click Save to overwrite the original image.
    • Click Save As to save the modified image with a different name.
Aug 25, 2008 | HP Photosmart D7160 InkJet Printer
Edges of Picture & Text Sloping
This mis probably a cold solder connection in the horizontal circuitry called the pincussion. Theres a couple of coils and resistors that overheat from time to time and the solder connections get loose. Not really for a handiman has this tv has hi vboltage inside even when turned off. Shouldnt cost an arm ans a leg to fix if the repair shop knows what they Are doing. Good Luck
Jun 26, 2006 | Akai CFT2490 24" TV
Blurred image
The viewfinder image should look sharp & clear, as long as the camera is turned ON. If the camera is OFF, the viewfinder image will blur. At least this is how it works on my C2000z. If your viewfinder is always blurry, I would return the camera for exchange.
Sep 07, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
