Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
We keep finding water at the bottom (inside) of refrigerator where vegetable trays are---Why is that plus ice on bottom of freezer
  • stacey_bates Feb 06, 2010
    we keep finding water frozen on the bottom of our freezer and on the inside of refrigerator where the vegetable trays are. What causes this? Our food is staying cold and frozen.
    My husband is about to begin working on refrigerator. After reading other solution we believe our problem is as you described. Thanks for your advise.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described m
ost times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section (not on all models, but this is the most common way), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups (in the top back of the fresh food section) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now (Whirlpool makes many of the Kenmore branded refrigerators) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 06, 2010
  • Rylee Smith
    Rylee Smith Feb 06, 2010
    To allow the water to go to the evaporator
    tray you need to unclog the tubing. Most refrigerators periodically blow warm air across the condensation tray.
    The warm air dries the condensation in the tray.
    Check the hose under your fridge that drains condensation and such into a
    catch tray. Make sure the hose is draining properly.
    Blow air through the tube to make sure it is not clogged. A coat hanger
    wire or a bicycle pump can be used to break up clogs or force air through the
    drain to remove any clogged material. To
    allow free flow of the air vacuum out the dust from under the fridge.
    The main reason of clogging is caused due to the dust, moisture and
    micro-organisms get together in the drain tube. Vacuum the dust from the back
    and bottom of the fridge. Please also check that the drain tube is firmly
    connected at all points. The drain tube can be flushed with chlorine bleach,
    rubbing alcohol or other anti-bacterial products which should be in consistent
    with the tubing material. Make sure that anti-bacterial product is not flown
    into the food compartment. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    President:
  • 2,468 Answers
Is the refrigerator compartment sweating in any area too?if so check the door seal and make sure the door seal is good as in no tears.kinks,etc. as this will let in warm outside air and condense in the cold compartment,if its dry and just one place with water,you may have a plugged drain line in the rear and its overflowing into the refrigerator area
Crisper drawers are feezing vegetables.
look down at the bottom crisper and there should be an air control that lets more or less air in from the freezer section. close this control down so that most of the air stays in the freezer. some models may say meats(colder) and vegetables(warmer).
some models the control in the down position opens up the vent more allowing it to get colder and in the up position closes the vent down more allowing less cold air into the refrigerator. you can remove the crisper and experiment with the control.
Jul 14, 2010 | GE Profile¿ Arctica® Energy...
Icemaker not making ice
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking inside of fridge - puddling below vegetable bins - is that the defrost cycle drain clogged up
In the rear of the fridge is a access panel. Remove it and check that the tray on top of compressor has water in it. If no, which I'm guessing it doesn't, then the drain tube is plugged. I like to cut the bottoms off for better drainage or at least make the hole on bottom a little bigger
Apr 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a model ET8CHKXKQ0 1 Whirlpool refrigerator and it keeps collecting water in the meat tray, the vegetable tray and under both vegetable trays. I have vaccumed under the frig., in the back and...
The drain in the freezer is clogging. When the defrost switches on, the backed-up ice thaws and starts dripping down into the fridge area.
Easiest is probably to turn off the fridge, let it thaw, then check the freezer drain to see if you can unclog it.
Otherwise, you have to pull out the bottom and back parts in the freezer (which will probably have some sort of ice frozen to them). Once you see the drain pan, get a turkey baster and flat head screw driver. You'll have to make a hole in the ice above the drain and squirt hot water until you hear it start draining. The drain hole is off center to the right in the drain pan.
Good luck
Mar 23, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water builup in bottom of fridge
If the problem is in the fridge 1: it could be moisture being drawn from unwrapped vegetables. 2: if you have a "wet wall" fridge check no food wrapping is touching the wet wall.
Mar 21, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice builds up in freezer bottom pan, not going down the drain tube. Is this an indicator of the defrost timer not working correctly, and if so where is the drfrost timer on a ETIFTTXKT02 model?
Defrost timer is working or there would not be water/ice in the bottom pan (as you describe it.). Check that the drain tube from the pan to the bottom evaproation tray under the refrigerator is clear of restriction.
Dec 14, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking from top part of freezer down to bottom of inside of the frig. Frost is on the top of the frig in the frigerator.
FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
Remove the food from the freezer compartment and place inside the refrigerator temporarily.
Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
Oct 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water in bottom of refrigerator has to be removed every couple of days or will come out onto the floor.
under the vegetable tray, a small drain hole is stopped up.Everytime you unit goes into defrost mode,the water is not draining to the defrost tray under unit
Sep 25, 2009 | GE Refrigerators
Freezer moisture overflowing into refrigerator
your drain is clogged, defrost the freezer and locate the drain either on the back or in the bottom of the fridge and clean it out. the water is coming from when the fridge goes into defrost
Sep 24, 2009 | Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
97 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
