When I turn my TV on, my DVR remote will not respond for 2-3 minutes even on my second new Motorolia DVR DCT6412 Cable receiver ever since I hooked up my new Samsung 46" HD- TV by HDMI cable. Why and would a Amplifier help boost the Remote signal to the DVR
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all you’ll need to check that all the cables are hooked up correctly as given in the link---
Digital Cable Box Hookup to HDTV
Amplifier cannot boost the remote signal to DVR. However, please check that the battery is fully charged or new in the remote. If this doesn’t resolve the issue then the problem may be with the processor failing due to which the remote is working after 2-3 minutes.
I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in.
Try using Component cables if this doesn’t make a difference. After using components cables your issue will be resolved.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 06, 2010
  • 5,138 Answers
Amplifier is not going to help with this problem ,you would really need someone to come in and CK everything out in order to know why you are having the problems you are having with your units.
I have the gray Comcast DVR remote control-it is so unresponsive!
I called Comcast about this today and they had me turn off the TV, unplug the DVR, unplug the coaxle cable, wait a second, rescrew in the coaxle cable, replug in the DVR. It worked! The DVR is snappy like it used to be. Such a relief because it was soooo annoying. Good luck.
Feb 28, 2010 | Televison & Video
DirecTV receiver R15 won't respond to remote RC23
Well, I took the DVR apart and found the power board completely intact, no bulging capacitors. However, the Mother Board had a 220uf/50volt cap that was bulging, so I replaced it. By the way, 'DigiKey' is the only place to go for electronic parts. They'll hook you up! The DVR still wouldn't respond to the remote. Darn it!
So I took both of my DVR's apart and swapped out the Front Board (the one with the Photoamplifier in it) and the DVR would now respond to the remote. OK, so now what do I do. I still have one DVR with a bad Front Board. I started to look on ebay for an old used R15 500 that I could swap parts from...remember, I own my eqipment and the goal is to preserve what I have recorded on the Hard Drive. R15's were going for around $50 -$80. Then I got to thinking. I still had an old non-DVR Direct TV Receiver in my closet I never planned to use again. My thought was: even though it wasen't the exact model receiver, it did use the same remote, so the frquency that the Photoamplifier worked at should be compatible.
So I took apart this receiver unsoldered the Photoaplifier. I then removed the Photoamplifier from my malfunctioning DVR and installed the part from my unused Receiver and it fixed it. So long story short(too late for that) the Photoamplifier was faulty. I tried doing some cross checking and a company in China called Raytron makes the part. The failed part did not have a part # and Raytron has several different Photoamplifiers that operate at different frequencies. This made it impossible to find the right part without schematics or knowing what the freqency is. So at least we now know what caused the non responce to the remote.
Jan 31, 2010 | Directv RC23 Remote Control
Dvr not responding
There was a software update early this morning which caused your recvr to go to recovery mode until it downloads the new software which takes about 4 hours. Once this is done you should be just fine!
Dec 10, 2009 | DISH Network DVR-625 DTV Receiver /...
Motorola dvr dct6412 locked channels
Check with your provider to ensure that you are in expanded services, or limited. Because being on limited services the box will lock you out of those channels. If you are in billing for those services and you checked the batteries on your remote and they are good and you get a solid red blink when you change channels not a double blink (indicating that your batteries are dying), Then try power cycling your DVR by, removing the power supply and waiting 3sec then plug it back in. Your box should shut off, turn itself back on, then go into the load screen, then, once the load screen display shows on your tv and on box display, wait for your box to completely load (don't touch nothing until the correct time shows up, meaning that it has completed the load process) Once the process is complete turn box back on and you should have you guide back up and (No Data) on your program schedule(Don't Worry!!) it will populate, with 15-20 mins.
Now try to ch. up and down and see if that fixed the problem. also make sure nothing is blocking the sensor. If all else fails and you changed the battery, called your cable provider and request a box swap, (be sure to watch all your recorded shows because they go bye, bye with the cable guy!)
Sep 22, 2009 | Arris DCT6200 DTV Receiver
I have a new LG HDTV. When first on the remote not responding.
Take the TV back.It should be under warranty.
LG/Zenith has had alot of problems with there TV's. Buy an extended warranty if you can. It will pay for itself.
Aug 02, 2009 | Directv HR22 500-Hours HD DVR
Motorola DCT6412 Cable box
Ive seen this before...that may be indicative of an upgrade of the software in the cable box that comes from your cable provider. The best thing to do is plug it back in, let it get the "yellow ring" for a bit, and wait for the upgrade (it make take 10 - 15 minutes). Then things should return to normal... If the condition persists, try to call the cable company.
Feb 03, 2009 | Arris DCT6200 DTV Receiver
DCT6412 DVR Box
When that happens its most likley you had a power outage and the box reset.  Well kinda reset but not all the way.  You can unplug the power and wait about 10sec and plug it back in and wait a few min to a few hours, and If that doesn't work get a new box.
Oct 04, 2008 | Arris DCT6200 DTV Receiver
Codes to operate a cable box with TV remote
Try code 038. If that doesn't work try 039.
Aug 05, 2008 | Televison & Video
Motorola DCT6412 DVR
I had the same problem before, and my cable provider told me to unplug your digital terminal for 60 seconds, then plugging it back in. It worked for me
Apr 27, 2008 | Arris DCT6200 DTV Receiver
Motorola dvr: model dct6412
YOU WERE RIGHT I GUESS IT WAS DOWNLOADING SOFTWARE, JUST LET IT RUN IT DOES TAKE A WHILE SO BE PATIENT.
Feb 20, 2008 | Arris DCT6200 DTV Receiver
Televison & Video Logo
Top Televison & Video Experts
