Is there any computer online using the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
The settings for the router have now been reset back to their default.
---------->>>>>>> OR:
Symptoms
You
need to restore the factory defaults using the web interface. This may
be because the router is not performing as expected or you wish to
remove all previously configured settings.
Setup steps:
Resolution
With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default.
Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
SummaryThis article describes how to reset the router to factory default
you then type in the above ip address to access the router and use the DEFAULT username password to enter router.Set up all according to manual and change the password for security.
Manual link Below:
http://www.belkin.com/support/article/?lid=en&pid=f5d5231-4&aid=1564&scid=220
