Question about AOpen MX34 (91.88510.101) Motherboard
I have a open desktop pc it is not work and there is no eny beeb
No beeb sound . i tried many times to replace ram and cable those things but there is no any display on my monitor. please help me out
thanks
    Guru:
  • 239 Answers
Unplug ur USB wires from ur mobo & try. Have u tried to reseat ur graphic card as well?
Posted on Feb 06, 2010
When i switch on my lenovo m58 desktop i get a beeb sound then the fan starts being loud then it automatically switches of then the loud sound from the fan continues....i've tried to remove the ram and the...
This is short false-alert of the time gap during start-up, and it happens on Intel based boards. Just take care of fan controls in BIOS, and try to locate missplaced fan connectors viewing the board layout. I know the lunatic who plugged a processor fan into system fan connector, and everything works fine, but monitoring is too bad, got it?
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Mar 18, 2014 | Lenovo ThinkCentre M58e 7298 Core Duo...
One continues beeb!
Take everything off of it that you can. No cables for keboard, mouse or monitor and try it. If it beeps then there is an issue with the internal components. If it works put the monitor on and see, then the keyboard, then the mouse and you can figure out what the issue is that way. If it still beeps then you are going to have to take the covers off and take out the RAM chips and the cards and any connections to the drives. Then try and see and put things back one at a time till you figure out what is causing the problem.
Feb 03, 2014 | Gateway Sx2370-Ur10p Desktop Black
One long!!!!!!!!!!! beeb when i turn it on! brand new!! never used before!
Sounds Like a RAM problem try swapping out some RAM. Try one stick at a time in slot number 1. I hope this helps.
My laptop is not turning to on
Seems to be problem in the Ram.
Step 1: Open the back cover where the RAM is located and take out the Ram and clean it with a soft brush and insert it back.(be careful while inserting the Ram coz you might damage it. insert it at an angle of 45 degree.
Step 2: If that didnt work then take out the Ram again and listen if there is and beeb sound. if there is the problem will be with the Ram Try changing a different Ram.
Step 3: If step 2 dosnt show and beeb sound then its obvious that its broblem with the motherboard(northbridge) or the display system.
Try Consulting a pro.
Sep 27, 2012 | HP Compaq nc6230 Notebook
When switched on, my packard bell imedia 1508/2 sounds long beebs and dosen't send any sign on the screen.no message shown.
Your RAM is not working properly. Remove your RAM from your RAM slot brush it with a dry brush and reattach in your RAM slot, if not then your RAM slot is damaged.
Jun 16, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
Every time i turn the computer on it freezes at the logo e machines when it starts and i cant press nothing on the keyboard, it doesn't detect it and its not the keyboard i even used a six pin keyboard i...
You say that you pressed all the fx keys and delete key. Were you trying to get into the BIOS setup? If the keyboard is frozen no amopunt of key combinations will work. You might have to reset the BIOS to default settings. That means connecting a couple of pins together for a short time on the motherboard. You may need the manual if you don't already know what pins. Just make sure the power is completely of and the mains cord is pulled out.
It can vary the amount of time required to reset but if the corrupted BIOS was not caused by an overclocking it should be instant.
Once it is reset put the pins connector back the way it was. You may then want to go into BIOS setup, to set things up again to your preferences or needs. Again depending on your knowledge have the manual with you.
Nov 26, 2009 | E-Machines eMachines T3830 PC Desktop
Intel desktop board D845wN - no screen display
HI,
Switch on your computer and listen for a beeb sound.... if no beeb sound available then your Motherboard has a problem.
if beeb sound comes then switch off your computer and see for the loose contacts on motherboard.
eg. remove ram, clean ram socket and put back the ram
your problem may solved.
thanks
ehsan (md_ehsan_1@yahoo.co.in)
Jun 15, 2009 | Intel Desktop Board D845WN Motherboard
Acer aspire sudden death my acer aspire L100 can't boot, only the noise of the fan and the DVD player. nothing else can anyone help please ?
Dear sir
if u don't get eny display 1 you need to cleane RAM then it's still not working you need to chek power suply.. and chek yr cables is attached is right or not.
simple.. if u need more help please contact feel free.. thianks..
Dec 15, 2008 | Acer Aspire L100 PC Desktop
Please help
The reason you are getting the beeps is because your computer has found Hardware problems. Different amounts and length of beeps mean different things. Laptops are different from Desktops so i cant tell you what it is but its most likely to be the RAM since you tried to change it.
When changing RAM: Not all ram is the same
1. Locate the original Ram. Does it Say DDR1 or DDR2. Make sure you get the same!
2. The Speed of the ram
PC66=66MHz SD Ram
PC133=133MHz SD Ram
PC1600=200MHZ DDR2
PC2100=266MHz DDR2
PC2700=333MHZ DDR2
PC3200=400MHz DDR2
PC3500=533MHz DDR2
PC5300=667Mhz DDR2
PC6400=800MHz DDR2
PC8500=1066MHz DDR2
Make sure both ram have the same specs and try to make it the same as the original stick.
When changing Hardware, be careful of Electro Static Discharge. Touch something metal like your computer case or a aluminum kitchen sink. Then static stored in your body may destroy the ram or your Laptop.
Oct 07, 2008 | Computers & Internet
AOpen MX34 (91.88510.101) Motherboard Logo
66 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
