Question about IBM Lexmark Z715 InkJet Printer
It pulls more than one page into the printer . is
It pulls more than one page into the printer . is there a adjustment ?
  • 742 Answers
Please check your printer's rubber roller that is responsible in pulling out the paper. Please clean it from any accumulated dirt.
Also, one important thing is that make sure that your paper is not to thin sheets preferably substance 16 and above. Also, shuffle the pages before loading to the printer tray.
Posted on Feb 06, 2010
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
Black streaks are appearing in the middle of pages. what can i clean of adjust to solve problem
Open the back pull down door and look at the fuser. Pay attention to the two long rollers.
I'm will to bet that one of them is damaged or dirty. If so, replace the fuser
Jan 17, 2011 | HP LaserJet 4250n Printer
My hp laserjet 3005 does has paper loaded in try 2 but always prompts me to load tray 1 to print. I would like the printer to print from tray 2 when it's loaded and try 1 is not loaded. Thank you.
Thank you for contacting FixYa with your printer inquiry.
This is a common problem. The device can be set to print from tray 1 if it is loaded, or to print only from tray 1 if the type of media selected is other than standard bond.
Pull out tray 2 and make sure the paper size adjustments are properly set to match your size of paper. If you are using std bond and the adjustments are set to A-4 it won't pull paper.
HP Control Print Jobs Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=1846088&prodTypeId=18972&objectID=c00764862
HP Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00764851&lang=en&cc=us&taskId=101&prodSeriesId=1846088&prodTypeId=18972
Hope this helps helps. Please keep us updated and remember to rate this answer.
Sep 02, 2010 | HP LaserJet P3005 Printer
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
support?
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
condition
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Troubleshooting
68
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
guides
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
Hi, if I am printing a form, my 5L printer cannot print the full pages, it runs into two or more pages.What needs adjustment? thank you
The issue could either be in your general printer setup (adjust the scaling % in the printer options) or in the application you are printing (adjust the page setup scaling % or it may possibly have the option to print 1 page high x 1 page wide).
Feb 10, 2010 | HP LaserJet 5L Printer
When I try to print docs from the web, the printer feed the paper but it get stuck after pulling eigth of the page. Copies are OK to print without problem
Clean the paper feed tray
and adjust the tray
Clean the paper feed tray with damp cl;oth
reset the printer to factory default settings if still does not work
....Go thru the manuals how take printer back to factory default settings
Sep 15, 2009 | Canon PIXMA MP460 All-In-One InkJet...
ERROR CODE SC45-20 MINOLTA 500
Color registration problem Restart copier and leave the front door open,will bypass the error code page.Press HELP,then press KEY OPERATOR MODE, scroll down to 21 EXECUTE ADJUST OPERATION, select COLOR REGIST AUTO ADJUSTMENT, then press OK, PREVIOUS SCREEN. After adjusting, it will back to normal. If the code number back on again, then it was the transfet belt off alignment. If you know how to pull the transfer back to center position, problem solve, if not, call technician.
Feb 11, 2009 | Konica Minolta bizhub C250 All-In-One...
Lexmark Opra M410 Laser
Your printer has a separation pad that is worn out and needs to be replaced. This pad prevents the printer from feeding multiple pages. It is located in the inside front of the paper tray Assembly.
Jan 06, 2009 | Lexmark Optra M410 Laser Printer
Printer setup
Continuous forms paper fed through the front of the printer also uses either the Front Push, Rear Pull, or Push-Pull tractor configurations. Make sure this is set correctly or it will reverse your margins.
It could also be your software. When you print through windows it's using the Microsoft system font controller, but your software could be setting font, margins, and alignment by the settings in the printer not in the driver. So if the first doesn't work, set your system back to align left then go into the printer configuration menu on the device and adjust the margins there.
Dec 15, 2008 | IBM 4247 Model V03 Matrix Printer
Missing pages
Your Doc feed needs new Rollers and Seperation Sheet/Pad, it is pulling pages, but not all the way, while the scanner continues to scan. the ADF might also need adjustment.
Jun 11, 2008 | Sharp AR-M237 Copier
IBM Lexmark Z715 InkJet Printer Logo
35 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
