Question about Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset
Try to connect it to my boost mobile phone and the phone does a scan but doesnt picks up the bluetooth signal from the headset
    President:
  • 1,738 Answers
Try this:
First, turn your bluetooth headset off. Then, start the scan to locate the headset on your phone. Just as the scan starts, turn your headset on. You may have to do it a couple of times to get it to work - but most headsets only go into pairing mode for a short few seconds just after being turned on.
Posted on Feb 06, 2010
How to connect a bluetooth to a samsung replenise
make sure bluetooth option is turned on and also make sure the bluetooth headset is turned on.. you phone has to search for the signal from the bluetooth so make sure your bluetooth set is compatable with your type of phone but i think most are. the after it finds the connection you might have to click on it to connect
Jun 26, 2012 | Boost Mobile Samsung Replenish Mobile...
I dont know how to able the bluetooth of blackberry curve 8520??
Here are the pairing instructions for the Discovery 610 to your mobile device.
Bluetooth Pairing Instructions:
Look in your mobile phones manual for the section that describes how to set up a Bluetooth wireless connection.
1. Move through the menu selections on your phone until the phone display shows "Look for Devices," or equivalent, as a selection.
2. With your headset turned off, hold down the call control button until the headset status indicator briefly glows blue, then flashes red and blue. The headset is now in discovery mode and will stay that way for 30 seconds.
3. On your phone, highlight and select "Look for Devices", or equivalent, to activate the scan for the headset.
4. When the phone display shows the scan results, select "6xx Plantronics". The phone will continue to search for the headset.
5. When the phone display asks for a passkey, type "0000" and press Enter.
Your headset is now linked to your phone.
I hope this helps.
Good luck from Headsets Direct - 800-914-7996.
Aug 03, 2011 | Plantronics Bluetooth Headset 610 Wireless...
Trying to connect Plantronic 220 headset to Pantech phone. Can't find the right option on the phone to engage the bluetooth device. I think the headset needs to be flashing red/blue to pick up device and...
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
Nov 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Lost instructions how to pair with my phone
Bluetooth technology is a way to boost your mobility when talking on the go. It similarly provides a wireless network for transferring files and pictures that you have acquired on a mobile device. Enabling and using this function can be beneficial whether for business or for pleasure.
  1. tep 1 Select from the menu "Settings" --> "Connectivity" --> "Bluetooth." This will bring you into the Bluetooth menu function, allowing you to configure your Bluetooth technology. In this menu, you'll find an option to turn Bluetooth on or off. Select "on."
  2. Step 2 Look for devices on the mobile phonemag-glass_10x10.gif that will be compatible with a Bluetooth device. There is a menu option to seek these devices. If a device is listed on the menu, you have the option to pair this device with your mobile phone. To do this you'll need to enter your security password. This is generally created when initially setting up your mobile device.
  3. Step 3 Check for the visibility option. The phone does have an option to either make your bluetooth device visible or invisible to other Bluetooth and mobile devices. It's your decision to remain private or broadcast your signal.
  4. Step 4 Use Bluetooth for data transfer. Once connected, you'll be able to transfer calls to your headset, transfer photos from your cell phone to your computer, transfer photos from your computer to your phone, and transfer files back and forth. Ensure your invisibility when transferring sensitive information to avoid hackers and losing information to other Bluetooth users.
Nov 15, 2009 | Nokia 2760 Cellular Phone
Bluetooth not accepting anything
The T-Mobile G1 doesn't actually support file transfer through bluetooth :S So it's not faulty, it's just not programmed to do that. Sorry! However it should be able to find your bluetooth headset, it always finds mine. Maybe the headset is faulty?
May 27, 2009 | HTC G1
N99i dual sim phone - can't connect bluetooth headset
not compatible througe the cell towers you may have to contact the service provider for other hardwear options.
May 02, 2009 | Dual Electronics N99i Cellular Phone
My H700 Motorola Bluetooth Headset
i just want to know how to get it to work in the first place... got a new phone and need to set it up but i lost my directions. how do i just get it to work
Oct 01, 2008 | Motorola Mobility H700 Wireless Headset
I cant scan phones using my bluetooth.
reset your blue tooth , pair it agian with your phone. remove all other blue toohts and pair it again. i hope that works .
Feb 17, 2007 | Motorola Mobility Razor Behind-the-Head...
Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset Logo
153 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Ed Nelson
Ed Nelson
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
