Question about LG 52SX4D Lamp
How to draw a schematic diagram of fluorescent lamp with its wiring?
  • LG Master
  • 12,061 Answers
Start at the left hand side of the paper... The Phase wire goes into one side of the ballast coil, the other side goes to one side of the filament on the tube. the other side of that filament goes to one side of the starter, the other side of the starter goes to the filament at other end, attaching to one side of the filament, the other side of the filament goes to neutral. The circuit is now complete, You also need a switch in the Phase to turn on & off.
Posted on Feb 06, 2010
I want t replace a mb2x40/120 rs ballast with a 120 277v electronic ballast how do i wire it
Rule #1: TURN OFF THE POWER AT THE BREAKER PANEL.
A fluorescent light ballast is a transformer that outputs a higher voltage than the input (120 volts). The electrocution hazard is very real.
Practically all ballasts have a drawing printed on the label. As a master electrician I still need the drawing to install them properly. Electronic ballasts should have a black and white wire for input voltage. The output to the lamps will be some combination of: red, yellow, blue.
The new ballast must also be matched to the type of lamp. Old fluorescent lamps were T12 (refers to the diameter). New lamps are T8 and produce more lumens with lower amperage.
Sep 27, 2014 | Electrical Supplies
Schematic wiring diagram
Buy a Hayes Book or Chiltons for your model. Schematic drawings are in it. Hayes runs around $25 can be found or ordered at most local auto parts stores. I always buy one every time I purchase a new (to me) vehicle , sooner or later I've had to use it. Good Luck !
Mar 09, 2014 | 1999 Dodge Durango
Cooper wiring devices 390-6107xx-eg1d wiring diagram
This is the Cooper product #6107; Standard Series Occupancy Sensor, 3-Way, 500W/400W, Incandescent, Halogen, Fluorescent Rapid Start Ballast.
Do NOT use to control light fixtures with CFL or LED lamps!
Connect this switch by using the diagram for the #6107 Single-Pole or 3-Way (match your existing switch) linked below.
https://objects.eanixter.com/PD365967.PDF
Dec 01, 2013 | Cooper Wiring Devices Electrical Supplies
New dimmer switch not working
Hi -
The Lutron D600P is a preset single pole dimmer. Wiring is pretty straight forward as show in this diagram. Recheck wiring and if OK, continue below.
If power is present on both wires (black / red wires), power is being passed through the switch to the lamp and the light should be on. If not, try replacing the lamp.
Minimum recommended connected load is 40 watts. This switch is ONLY for use with filament type lamps - such as traditional tungsten, halogen, etc. It is NOT to control speed of Fan Motors, nor dimming of CFL (compact fluorescent lamps) energy saving types or other ballast operated lamps such as High (or Low) Pressure Sodium, Metal Halide, Fluorescent, etc. as this would create a high heat condition and could cause a fire.
If you're still having trouble, you can contact Lutron Technical Support Center 1.800.523.9466 24 hrs / 7 days www.lutron.com
I hope this helps & good luck!
Sep 02, 2012 | Lutron #D-600PH-DK 600W SP Push Rotating...
Hunt dimming fd
Ok - a couple of things, first - when a dimmer is set to minimum; zero to a barely perceptible level of light output is expected. Second, fluorescent lamps have a much shorter range of dimming that the standard incandescent lamps have. It is not unusual for a fluorescent lamp to remain off until the dimmer is at or above the half way point in the dimmer's range. Third, you can not dim a fluorescent lamp or fixture unless the lamp or fixture is specifically labeled as being "dimmable". Use of a dimmer to control brightness of fluorescent lamps and fixtures that do not clearly indicate they are designed for dimming or to control the speed of motors like those in "paddle fan & light fixtures" creates a dangerous fire hazard condition. Most CFL (compact fluorescent lamps) that readily replace the screw-in incandescent type lamps and are clearly labeled as dimmable, can be used with a standard dimmer. The traditional (non-CFL) fluorescent fixtures that have a internally mounted and hard wired internal ballast need a special dimmable ballast to operate.
Feb 02, 2012 | Philips Electrical Supplies
I NEED A WIRING SCENATIC FOR AN INVACARE PRONTO m6
I assume you need a wiring schematic for an M61. The circuit board schematics are proprietary and not available. The component schematics and interconnects for switches and wiring harnesses are available, as are the parts diagrams and drawings. Please clarify your specific need and issue.
Oct 10, 2010 | Invacare Health & Beauty
Wiring diagram
1997 Saturn SL 1.9L MFI SOHC 4cyl
1991-98 Starting, Charging, Fuel Pump, Cooling Fan, and Headlight Schematics
1995-98 Stop Lamp and Turn Lamp Schematics
1991-98 Marker Light Schematics
1991-98 Back-up Light and Daytime Running Light Schematics
I hope help you with this. Good luck.
Sep 14, 2009 | 1997 Saturn SL
What are the white balance modes available with the camera?
The following White balance settings are available for the A1: AUTO, Preset (Daylight, Tungsten, Fluorescent, Shade, Cloudy, Flash and Custom1 to 3) The following slight adjustment is possible: * At setting Daylight, Tungsten, Shade, Cloudy and Flash: +3 to -3 (one unit is approximately equal to a 10 mired shift.) *At fluorescent lamp setting: equivalent to 7 fluorescent lamp(3 -wavelength colored fluorescent bulb, 3 wavelength white fluorescent lamp, 3 -wavelength neutral white fluorescent lamp, 3-wavelength daylight fluorescent lamp, white fluorescent, neutral white fluorescent, daylight fluorescent lamp)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
LG 52SX4D Lamp Logo
547 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
J.D. Browning
J.D. Browning
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
