How do I remove hotpoint agitator - Washing Machines
    Sergeant:
    Champion:
  • 263 Answers
Usually you just pull it straight up real hard.
Hotpoint washer repair orange county, ca
Posted on Feb 06, 2010
I got the strap of my swimsuit stuck under the agitator of my Hotpoint washing machine. I removed the top layer of the agitator, but don't know how to get under the part beneath it.
With the first part of the agitator off you now have to remove another cap off the top of what you now see. Under that will be a bolt that holds the whole bottom of the agitator on.
Feb 28, 2015 | Hotpoint Washing Machines
I have a new Hotpoint washer (top load) model HTAP1200DWW i have a string stuck under the agitator. I removed the top cap on agitator but there's another plastic cup a little lower down the shaft. My...
Most just pop out. If you can get your fingers from both hands at 3 and 9 o'clock under agitator and pull up quickly and firmly, it should pop out.
Aug 25, 2017 | Hotpoint Washing Machines
Need to make spin the agitator on a Hotpoint Heavy Duty Washer
Drive belt broken call GE Parts for new belt , They stock for all makes ,,
Aug 17, 2012 | Hotpoint Washing Machines
Can't remove agitator on hotpoint washer
I have this same model of Hotpoint washer. I pulled up on the agitator and that separated it from the hub. I removed the hub by loosening the bolt at the top of the hub with a socket wrench. I removed the hub after removing the bolt. I removed the long stringy fabric by unwinding it and lifting up. that's all there is to it. Really simple. Everything went back together very easily. Only hard part is lifting the agitator up with enough force to free it from the hub.
Aug 10, 2012 | Hotpoint Washing Machines
Maytag top loader HE: coin under impeller(agitator). how to remove agitator?
Take a water hose and blow it out.
G.e. Agitators normally need a special puller to remove tub
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 05, 2010 | Hotpoint VBXR1090D Top Load Washer
Old top loading Hotpoint washer---the agitator squeaks and eventually works loose & floats up & doesn't agitate--is there a way to easily re-attach it? (Can't find model number, but it is gold,...
Remove the agitator. The splines on the agitator transmission shaft need cleaning. They are at the top of the shaft. Take a sharp pointed knife and carefully clean the grooves of the shaft.If memory serves me, there are 13 grooves. You will also have to replace the agitator spline coupling found inside the top of the agitator.
You will have to cut out the top of the agitator and use a punch to knockout the old coupling.Do not cut out the entire top,only a circle about the size of a quarter.
Put the new coupling on the agitator transmission shaft,put a little liquid dish detergent on the rubber part of the coupling and place the agitator over it and push down hard until it seats.
Jan 01, 2010 | Hotpoint Washing Machines
I got the strings of my sweat pants stuck under the agitator of my old Hotpoint washing machines. How can I remove the agitator to untangle it?
At the top of the agitator has a cap get a flat screw driver and pry up and turn. When it comes off there is a nut you have to take off.Then pull up on the agitator..
Jan 15, 2009 | Hotpoint VBXR1090D Top Load Washer
Hotpoint washer
  These older units had an insert in the agitator that would strip out.  Remove your agitator and take to a parts store. They should be able to help you out.
Oct 11, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Hotpoint washer
Two types of Hotpoints had two different ways of removing the agitator. One had a pop off top that when you removed it, you can remove the center bolt, the remove the agitator. Another one you had to put your fingers under the agitator and pull straight up to unclip the agitator. Good Luck!!! Jim
Sep 04, 2007 | Washing Machines
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
