Question about Blackberry Curve 8350i
The ball wont roll on my blackberry. Help! - Blackberry Curve 8350i
The trackball is easily removed for cleaning by just pulling the trim ring around the trackball off with your fingernail. Remove the trackball and clean with alcohol. Reverse the process to clean.
Posted on Mar 02, 2010
  • 19 Answers
The quickest and easiest way to clean it if you're not at home or dont have the time or space to take apart your blackberry trackball and do a thorough clean, is just this;
1 - Get any piece of flat, new paper.
2 - Turn your blackberry upside down (trackball side down)
3 - Slide your blackberry around in circles and over the stuck trackball part.
4 - Keep doing that until it clicks when it rolls, like normal.
Quick way to unstick.
Posted on Jun 28, 2011
    Problem Solver:
  • 5 Answers
It not a big deal, just use a sliced plastic straw to clean it. Lots of people have known this trick and they have proven it useful and effective. I found this trick at: http://www.unique-stuff.net/fixing_sticky_blackberry_trackball.html
If you still cant get your blackberry trackball roll, they also have some other tricks to try.
Posted on Apr 30, 2011
    Problem Solver:
  • 11 Answers
You would just have to use a pin and pull out carefully the ring around the trackball. then this is the most imp part take the trackball carefully. you can go here and see how the trackball looks like
http://www.asia.ru/en/ProductInfo/1810650.html
take a few pics of the trackball from the sides.
i made a mstake of not taking the pics of the trackball. from the side open the trackball carefully.be carefull because all the stuff inside are tiny. there shall be something very small stick kind of stuff
those are the rollers.clean the rollers it may have something stuck on it. remove those.now is the use of the pics you have taken. fix the trackball lookin at the pics.
put everything back to how was and your scroll will work perfectly
because i didnt take the pics i didnt know how to put it back and then i broke my trackball
Sorry for using so much 'carefully' in the solution
Posted on Aug 27, 2010
    Scholar:
  • 59 Answers
If need be, you can buy a replacement ball off eBay for about $4 with instruction on how to replace it.
Posted on Apr 17, 2010
    Problem Solver:
  • 9 Answers
Hai. Sometym that is a problem with the trackballs. It may also be dirty so just need some cleaning. If still problem when cleaned try send for service. Maybe a gud idea is to change the pouch if your using a slide in
Posted on Feb 06, 2010
Blackberry ball wont roll
If the track ball is stuck, there's something that's preventing it to roll. Cleaning it should be the solution, but you need to contact the manufacturer and have them clean it for you. Because that track ball is not easy to remove.
Thank you!
Dec 29, 2009 | RIM BlackBerry Pearl 8100
Ball on blackberry wont navigate up or down
Hi. BlackBerry smartphone trackball fails to roll in a particular direction because, debris is lodged in the trackball.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in a desktop computer.
Using for certain period debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
If rapidly rolling the trackball does not correct the problem, please contact your wireless service provider for support options.
I hope this information will be helpfull.
Nov 11, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
I can't scroll down with the rollerball
The balls on the blackberry's get clogged up with finger oil, skin, and all sorts of grime I think. But I fixed mine by shutting the phone down and then rubbing hard against the roll ball in each direction and pushing each time until the clicker under the roll ball clicked. You could also try alcohol.
Oct 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
Ball wont roll up, will roll every other direction
the ball is likely dirty. you can actually remove this if you are extremely careful and try to clean the ball with alcohol and a q-tip.
Jul 10, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Ball wont roll left
Cause:
The sensitivity of the trackball/trackwheel might be less
Faulty Hardware
Resolution:
Increase the sensitivity by following procedure
Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100
if still not working contact service center
Jul 08, 2009 | RIM BlackBerry Pearl 8100
The ball won't scroll down
Have you removed the ball at any time? If it is put back in wrong, it could cause this. If not, the ball assembly itself might be bad. You can find them fairly cheap on eBay.
May 30, 2009 | RIM BlackBerry 8800
Blackberry rolling ball issues
Is the ball registering left right up and down and just not selecting? Sometimes the ball gets dirty. You can clean them most of the time. If its the actual select button, it sounds like it needs replacing. This repair runs 65.00 plus shipping. The actual button is a solder-on button so it requires more attention. Try http://www.pdasmart.com for your blackberry repair needs!
Apr 08, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry rolling ball will not roll down
Cleaning the track ball on blackberry phones. Remove the metal ring then the ball mechanism remember how you removed it because it needs to go in the same way. You can also try removing the battery from phone taking a qtip with alcohol the higher the percentage of alcohol the better. and wiping and rolling the ball around even without removing it from the phone. this usually helps unless the ball is extremely dirty. Below are step by step ins for removing the ball. just follow the link
Removing blackberry tracball (non BOLD)
Dec 28, 2008 | RIM BlackBerry Pearl 8100
Blackberry curve's roller ball does not go up
Clean the ball.  Put some alcohol on your finger and roll it around.  This worked when the same thing happened to me.
Nov 20, 2008 | RIM BlackBerry Pearl 8100
Trackball on Blackberry Curve not working properly
I found that removing the track ball and cleaning the contact and track ball with a cotton swab moistened with a small amount of isopropyl alcohol, it worked a 100 percent better when I returned the ball to the handset. DO NOT SATURATE THE BALL OR THE HANDSET WITH THE ALCOHOL!! ONLY USE A VERY SMALL AMOUNT!!!!
Oct 13, 2008 | RIM Blackberry Curve 8300
Blackberry Curve 8350i Logo
300 people viewed this question
Top Blackberry Cell Phones Experts
raysaw
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Blackberry Cell Phone Expert? Answer questions, earn points and help others
