Question about HP Officejet 5510 All-In-One Thermal Printer
OPEN THE DOOR FOR MY HP 5510 PRINTER TO INSTALL THE CATRIDGE
    Scholar:
  • 93 Answers
Please follow all steps here to install the print cartridge:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033420&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=311255&lang=en
Thank you
TechSaver
Posted on Feb 06, 2010
How do I insert the ink cartridge
power on the printer, open the catridge door. after printer initializes the catridge carriage assembly comes to right side of the printer and settles then insert the catridges and close the door.
Oct 17, 2014 | HP Office Equipment & Supplies
I have a problem installing my printer (hp laserjet 1010)it gives me 0*000006ben how do i solve it?
I HAVE A PROBLEM THAT HP LASERJET 1020+ PRINTER TONER CATRIDGE MISSING OR FRONT DOOR OPEN ERROR
Oct 29, 2013 | HP LaserJet 1010 Printer
Still getting Print Cartridge Error after installing new HP cartr
please check the position of the catridges installed. it should be in a correct position. or you might have replaced the catridges in a wrong slot. if it does not work out then either connect your printer to different computer for printing or uninstall the software from your computer, then again reinstall the software.
Oct 29, 2009 | HP Officejet 5510 All-In-One Thermal...
Paper jam hp 5510
Look in the rear of the machine for an access door.
Jan 04, 2009 | HP Officejet 5510 All-In-One Thermal...
How to remove catridge from printer J4580
Pull open the front door.
instructions for installing are in the box with the new cartridge
Dec 26, 2008 | HP LaserJet 4650 Color Printer Manual...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Changing cartridges
for the 5510, the manual says to turn the machine on, then lift the catridge cover piece, which is the flap under the hp symbol on the scanner/copy part...it's the flap that hangs down just above where your print copies come out...it takes a little tugging, but it comes up and then you can see your cartidges...after that, push down on the cartridge and pull it out..
Mar 15, 2008 | HP Officejet 5510 All-In-One Thermal...
REPLACING INK CARTRIDGS
For HP 5510 series for replacing the cartige, you need to lift the door just above the paper tray. Pull out the old cartidge, hold it so you can see the way it is inserted and click in gently in the same way.
Nov 19, 2007 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 All-In-One Thermal Printer Logo
189 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
