Question about Refrigerators
I managed to put a pin hole leak in my freezer compartment, what can I use to seal the area. I plan on crimping the aluminum at the hole useing a smaller punch, and sealing that with silver soder. How many PSI is there on a typical compresser driven refridgerator freezer? Also how much is the typical cost to have a smaller 18 cui or less recharged for use?
    Sergeant:
    Champion:
  • 263 Answers
It will not be as easy as you think. It's easier to use a rubber with a clamp or get a whole new evaporator. You'll need to change a filter-dryer as well, install valves. It's a big 1-3 hour job.
maytag refrigerator repair in orange county, ca
Posted on Feb 06, 2010
The 'H' frame leaks
If the unit was installed buy the agent then they are responsible to stop the leak don't let them get off of taking care of it. make sure they are pulling the unit off the roof to replace the gasket and just putting silicone around the edges because it will just pull a loose when pulling camper due to body flex. if you put plastic over unit you know there is no water leaking from inside the unit so it only can becoming from around it. Bad seal
Jul 03, 2014 | Dometic Rooftop RV Air Conditioner
What do i need to repair a hole in oil pan of car
Are you sure it is a hole in the oil pan? Is this a steel pan or aluminum? If there is oil all over uder the hood I would suspect a front seal or a pan gasket, then the belts or fan can blow it around. I would first give it a good wash, top and bottom so you can pin point where it is coming from. If it is a hole in the pan I have seen a few temperary repairs that seemed to work for a while. You would need to drain your oil, then clean the area very well with brake clean and a wire brush, make sure you have it good and dry. Then you can use J B weld (a two part glue) and smear over the area. I have seen some people use seal-all and a peace of cloth. Some people have used a screw and spun it up into the hole with a little silicone, but the best way would be to remove it and get one from a auto wrecker or take it to a shop to get it welded! Hope this helps , good luck!
Feb 16, 2012 | 1996 Chrysler Cirrus
How do you fix the oil coolant line?
I assume there is a pin-hole in the line? Easiest way is to find the leak, cut it out, and reconnect with the right size fuel hose (should be 1/4" or 3/8"). Make sure to use small hose clamps to connect the hose
Jan 25, 2011 | 1989 GMC Sierra
FREEZER KEEPS FREEZING UP THE DEFROST HOLE AND KEEPS LEAKING WATER IN THE REFRIGERATOR EVEN WHEN THE FREEZE IS EMPTY NOT BLOCKING AIR FLOW
Good day,
Common problem on Whirpools.
The drain hole is only the beginning. From there it goes to a cup in the fresh food compartment, where it travels thru a boot to the outside of the machine,then down to the drain pan.
That all has to be taken apart and cleaned completely. Just getting it open is not god enough.
As well, even though you can't see it, that hole in the freezer, is part of a large aluminum panel that runs up the back of the freezer coil. Ice will form on the back side of that panel, and cannot be seen.
The only solution is a 24 hour shutdown, unplugged with both doors open. Better with a floor fan, positioned to blow air into the freezer compartment.
Long and ugly, but it works.
Thank you for using FixYa
Jan 23, 2010 | Kenmore Refrigerators
I accidently punctured a hole in a cooling tube in a small kenmore fridge freezer and lost all the coolant.. i have since repaired the hole but can't seem to find the fitting on the compressor to recharge...
If you punctured the aluminum tubing or the freezer aluminum evaporator , it cannot be repaired . If the puncture is in the copper tubing , only silver solder will fix . On the compressor , you will see a short piece of tubing , capped off . This is where the access fitting was . A good technician will ALWAYS remove the access valve , due to possible refrigerant leak . After removing the end of the tube , silver solder another valve into the tubing . Evacuate the system , recharge with correct amount of refrigerant , crimp the tubing at the access valve and remove the access valve . Re-solder the end of the short tubing , and it's done .
Oct 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaks from top mounted freezer area into the refrigerator
Remove the food from the freezer and the icemaker if equiped . Remove the air tower at the rear of the freezer section and remove the rear panel inside the freezer . Using a hair dryer to the drip pan , below the coils ( probably ice ) , starting at the center , defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water starts to flow down . Using a short piece of hose , insert it into the drain hole and blow . This should blow out any debris inside the drain hole . I would use a short piece of solid ALUMINUM wire ( 14-16 guage about 8 " long ) striped of all insulation , and insert it into the hole as far as possible , without any force . Wrap the other end about 1--1 1/2 turns around the black tube ( defrost heater ) above the hole . When the heater comes on , heat will transfer to the aluminum wire and keep the drain from freezing up again . Reasemble back panel , air tower , and , icemaker . Reinstall the food and its FIXYA'd .
Sep 02, 2009 | Refrigerators
Fridge that is leaking
Remove the back panel of the freezer . Use a hairdryer on the drain (aluminum enclosure) to defrost the ice .Once you see the drain hole , keep defrosting hole until only water in the hole . Use a small hose and blow into the hole to blow out any debris . Using an aluminum fence post holder about 6" long , put into hole and wrap about 1" around the calrod heater . This will transfer heat to the hole to keep it from freezing up .
Jul 06, 2009 | Refrigerators
Freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
May 31, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
May 27, 2009 | Frigidaire 26.0 cu. ft. Side-By-Side...
I have water pooling on my fridge trays and than turning into ice . The water seems to be coming from the vents. How do i get rid of that.
The freezer compartment has a drain hole behind the back wall inside the freezer compartment. The drain hole has probably rusted and has gotten larger. Carefully remove the icemaker and the screws from the back wall inside the freezer compartment. Lift the bottom of the back wall and look to see if the drain hole has gotten larger. You can make a small funnel from an aluminum can to fit over this area directing the water into the drain tube. It worked for me. good luck. Dave.
May 10, 2009 | Whirlpool ET9FHTXM Top Freezer...
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
