Question about Philips 32PF5320 32 in. HD-Ready LCD Television
Multiple Problems When changing anything (channel,volume,etc), menus won't disappear from screen, Cannot see the channel when trying to change to a specific channel. Closed Captioning won't turn on when activated
  • 3 more comments
  • Naz207 Feb 27, 2008
    THANKS BUT IT DID NOT WORK. STILL HAVING THE SAME PROBLEMS
  • Naz207 Mar 09, 2008
    how do you reset default settings?
    I opened menu, went to settings, but there is no default only auto, ntsc, pal-m, and pal-n.
    what is a decoder?
    I have no universal remote just what it came with.
    when you say disconnecting do you mean turning it off or taking it off the plug?
    Brigadier General:
  • 6,966 Answers
With the indulgence of micromaster, otacon, IB4G2008 and sweet_rascal...
Based on your post, I will assume that:
1. basically the TV works except for certain issues with the OSD (on screen menu/display);
2. you are using the original remote that came with the unit and there is nothing wrong with it also.
If that is a fair assumption, then you would need to update the firmware of your TV. It would seem that you still have the 1st version with some bugs which have been ironed out in their latest firmware that includes OSD problems. A bit tricky to do though.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 12, 2008
    Guru:
  • 1,894 Answers
Hello sir
you will have to buy a universal remote separately for that
    President:
  • 1,944 Answers
Did you try disconnecting the unit for a few hours to hard reset it?
Posted on Mar 09, 2008
    Brigadier General:
  • 3,614 Answers
I want to know if you are using a Decoder, Universal Remote Contrrol?
If so please provide me the detailed info about the device model and the brand.
Kindly regards,
-micromaster
  • micromaster
    micromaster Mar 09, 2008
    When you got that problem what the initial status of the unit before it happen.
    Kindly regards,
    -micromaster
    micro & yakman unltd.
  • micromaster
    If there's a CALL button on the remote press it.
    Genius:
  • 3,587 Answers
Sounds a lot like processor lock up..did you have a power glitch recently?
turn off the system, for at least 5 min, and then, try it on manual mode..without remote..
Posted on Feb 21, 2008
  • 2 more comments
  • Patrick Michaels
    Patrick Michaels Feb 27, 2008
    ok..can you access the menu, and reset the default settings?
    sounds like your memory got scrambled..
  • Patrick Michaels
    Patrick Michaels Mar 09, 2008
    open menu go to settings choose default press enter or select...
  • Patrick Michaels
    a question for you ? do you have the original users manual for this unit?
  • Patrick Michaels
    Patrick Michaels Mar 12, 2008
    Nazman..seems that you are ready to call the service dude...let it rest..there's no more to get from fixya
VIZIO E470VA LCD HDTV Dish Hopper remote doesn't change volume
Try another remote code, many of the Dish or Cable TV remotes will have multiple codes for a particular brand of TV's
Sep 01, 2012 | Vizio E470VA 47 in. HD-Ready LCD TV
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
VIDEO PROBLEM SAMSUNG LN46A630 I have a SAMSUNG LN46A630, after turn on the TV around two hours the screen goes black - the video disappear, some time the video come again the sound doesn't go, you can...
The Tuner signal board have intermittent problems.Tries websites like Shopjimmy.com,Ebay.com to by a refurbish Tuner signal board for the replacement.
Oct 16, 2010 | Samsung LN46A630 LCD TV
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Black box appears in middle of screen
Hello tinycc88,
turn off the TEXT MODE in the closed caption menu.
tvdan
Mar 15, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Sony bravia tv
Press Display button on remote once and on screen dsiplay will disappear.
Sep 12, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Cluster of stuck pixels
sounds like its stuck in another mode. Do you have the original remote to sdee if you can switch off the display section or the closed caption?? good Luck
Jul 28, 2006 | Toshiba 20AF43 20" TV
Philips 32PF5320 32 in. HD-Ready LCD Television Logo
88 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
