Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
The heater goes out often. has a flashing light
The john woods superflue
3 Suggested Answers
SOURCE: My Superflue water heater is flashing Eco failure.
I have the same issue on a Superflue 6G50NVH 04. I don't see a red button and after I cycle it off and on, it stops within seconds. The water is freezing - so it certainly has not overheated. Is this something I can fix myself? How?
Posted on Apr 07, 2011
  • 351 Answers
SOURCE: no power at all to my superflue water heater
Hi, first check and try and reset the breaker feeding the water heater. That should be a two pole breaker. The next thing to check is the red safety button on the top thermostat control. It is under the top access panel of the heater, along with a good amount of insulation. Push the red button to reset the safety switch. If these do not remedy your situation, then you will need someone on site to check the water heater in more detail.
Posted on May 03, 2010
I have a John Wood powervented gas water heater, model 322152-001(13-05). The temp pressure relief valve is leaking. How do I operate/reset the valve manually?
There is a leaver YOU CAN PULL up but this may not stop the valve passing it may wash any dirt of the seating ,It may be best to change the valve .
Dec 19, 2016 | Water Water Heaters
Superflue. Why doesn't it stay lit?
If this is in a RV there is a propane monitoring valve. It will close and cut of the propane if it is not being used for a period of time or if there is a leak. The valve is mounted between the propane tank and the first appliance, usually inside the RV.
Mar 09, 2016 | Water Water Heaters
I have a GSW Superflue power vented electronic ignition. It lights and fires up for 15sec then goes out. Keeps doing this. When I open the two front covers the flame stays lit and strong. As close the...
definite air intake problem . check the filter at the bottom of the unit. and keep the area around the unit clear and clean to prevent recurrence
Jan 28, 2015 | Water Heaters
Propane hot water heater
Troubleshoot service manual by type of gas control valve
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Post question on following link:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment and say what you discover
Jun 28, 2013 | Water Heaters
I have a John Wood one pipe power vented hot water heater. The model number is Jw840nvh-fv-04. Recently I've been smelling products of combustion coming out the top of the tank where the vent is
1) Copy following link for troubleshoot resources by type of gas control valve, Venting resources, and pro water heater forum:
2) This odor can indicate incomplete combustion due to lack of air supply. Get more fresh air to unit. Check that flame is clear blue color. John Wood is American/AO Smith product so air intake screen is located on bottom of unit. Use mirror and flashlight to inspect. Clean with compressed air ad or feather duster.
3) Jw840nvh is 40 gallon natural gas. Natural gas is lighter than air and rises upward, unlike propane gas that is heavier than air. Install gas detector at height correct for type of gas.
4) For safety, install CO carbon monoxide detector
5) Review product manual for correct vent lengths and diameters.
Feb 02, 2013 | Water Heaters
No power at all to my superflue water heater
Apr 05, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Superflue heater will not light
The self igniter, or thermal couple is bad.
Mar 27, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
My Superflue water heater is flashing Eco failure. What is this? What do I do?
The ECO is short for emergency cut off.
The ECO is either tripped or it went bad. You may be able to reset it or you will have to contact a rep the sells your heater to get a new part. Some are resetable and some are not... not sure which you may have. The reset ones will have a little red button to push in the center.
The next rpoblem is to figure why the ECO went or tripprd in the first place. There is probably a reason or a cause. When you refire it make surte you donot have flame roll out and proper venting. Also make sure the the thermostat works and is not letting it get too hot.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 08, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
314 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
