Question about Nikon FE 35mm SLR Camera
Shutter does not release - Nikon FE 35mm SLR Camera
  • fsweda Feb 06, 2010
    I have new batteries . was told to turn slot on bottom of camera clock wise . it worked . Shutter released camera works fine
  • kakima May 11, 2010
    The first thing I have to ask is whether you have a fresh set of batteries installed. Either way, try turning the shutter speed dial to the M position (or M250), **** the shutter, and try to release the shutter. Does that do anything?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Glad you got it working.
Posted on Feb 06, 2010
Long exposure? how dp you acoomplish this using the pentax k-1000
You will need an external shutter release that locks. Connect the shutter release, then on the camera set the shutter dial to B (bulb). With the shutter release cable fire the camera and lock the plunger, or hold it down. Using a shutter release cable you are less likely to cause camera shake. Of course have the camera on a tripod or something steady.
Jan 27, 2014 | Pentax K1000 35mm SLR Camera
Is it possible to achieve a 20sec shutter release via remote control
With or without the remote control, in the M exposure mode you can select the bulb/time setting. Without the remote, this opens the shutter when you press the shutter release and holds it open while you keep the shutter release pressed. With the remote, this opens the shutter when you press the button on the remote and keeps it open until you press the button again. This allows you to keep the shutter open for up to 10 minutes.
Nov 29, 2010 | Nikon Coolpix 8800 Digital Camera
Nikon d90, blinking "Error"
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
Feb 18, 2010 | Nikon D90 Body Only Digital Camera
Cable releases will not operate shutter of Pentax A3
Take one of the cable releases and press the thumb pad and extend the release probe. Lock the release in the fully extended position. Try inserting the probe into the shutter release hole and see if it works. If not then try using a thick needle from the head end and see if the release actually works on the camera. If it does then measure the depth that the needle goes to in order to work the shutter and compare to the exposed length of the release cable. You may find that it is not long enough although I would have thought unlikely.
Oct 02, 2009 | Photography
Shutter won't release
If the lighting is low and shutter speed is set for a long period of time its the function of the camera taking the picture. If it is a malfunction of the shutter take it in for cleaning you might have foriegn material stuck in your shutter mechanism
Jan 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Shutter stopped working
If the metering lights go out when you press the shutter release fully down, then the camera needs the shutter capacitors replaced. If they stay on, it could be the release magnets on the shutter unit itself, or worse.
Aug 12, 2008 | Minolta Photography
Shutter release
Hi , to release the shutter open the lense and push shutter button , rotate the camera mode to auto or manual release shutter.donnot set on bulb or lower speed can cause stuck camera miror and stter curtain, or blade.
Feb 19, 2008 | Photography
Shutter-release
After the focus is confirmed, the Shutter-release time lag for the DiMAGE E201 is approximately 0.4 second. If the shutter-release button is depressed in a quick motion without making any pause to confirm focus, approximately 1.9 second is necessary.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Nikon FE 35mm SLR Camera Logo
494 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
