Hi i have a wd -82837 i need acode to set wite my bose hometheater v20 audio system
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
SOURCE: How do I connect my iPod to Bose Lifestyle V20 System
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
Posted on Feb 01, 2009
SOURCE: System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Posted on Feb 05, 2009
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
Posted on Mar 10, 2009
SOURCE: The remote for Bose lifestyle V20 system does not
I had the same problem, and called Bose tech support. They put me on track to the solution. The code you need is under AUX, Music Player, Apple where you probably looked already. The secret is that you need to "unpair" the apple remote first. If I remeber right, in apple TV you go to settings, general, remotes and unpair your remote. It still works, but is no longer the only remote that works.
Gerry
Posted on Jul 23, 2009
I had Bose lifestyle V35, V20 try to link together. Bose link AL8 transmitter will not connect to receiver. both led is light solid green. Please help.
The commands for the Bose link system are actually going through the remote control system. In order to use the system you need not only a set of AL8 sender and receiver, but also a special remote control model RC48S2-40 these model numbers are slightly different for the US and for Europe. In addition you will need to activate the BoseLink connection through the system settings menu and you will need to tell the remote to which system it needs to talk. When you have done all that, there should not be any problem to "connect" the two systems. If this does not work, you may need some specialized help from a Bose specialist who understands this multi room set-up.
Nov 09, 2014 | Bose link AL8 wireless home-wide audio...
Tip
Bose LifeStyle V20 Manual Download
Download Bose LifeStyle V20 Audio System Manual
Would you like to review the features of the Bose LifeStyle V20 Audio System?
Have you lost your Bose LifeStyle V20 Audio System Owners Manual?
Would you like a digital, searchable, pdf version of the Bose LifeStyle V20 Audio System Users Guide?
Follow this link (& click FREE) to download a pdf version of the Bose LifeStyle V20 Audio System documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Audio Players & Recorders
Tip
I hope that helps.
on Jul 03, 2010 | Bose Lifestyle V20 System - black Theater...
Bose lifestyle v20
Make sure the HDMI device (TV, Blueray player) is set up for audio output. Usually HDMI 1 is the only connection that has audio out. Also some TVa have to be configured for HDMI audio out.
Dec 07, 2013 | Audio Players & Recorders
I just bought my V20, I plugged it using a HDMI from my dvd to my v20 for the image, and a digital cable for the sound. My image works perfectly but I have no sound. I noticed that the light under my...
Hi - Don't know about the switching LEDs but there is no reason to be using both the HDMI cable AND a digital coax cable to the V20.
You should have a single HDMI (carries video and 5.1 audio) cable from the DVD to the DVD input in the V20.
Regards,
Mikeywaf
Mar 19, 2011 | Bose Lifestyle V20 System - black Theater...
Tip
I hope that helps.
on Jul 03, 2010 | Bose Lifestyle V20 System - White Theater...
Do i need to have the bose system turned on in order to watch tv or can i have the cable box bypass the bose receiver? I do not wish to use my bose for everyday tv. Thanks
If your TV has its own speakers you don't need to have the Bose turned on for Lo-Fi watching. Not knowing what your TV has for analog and digital inputs or your Cable Box has for analog and digital outputs...
The LS V20 has 3 analog inputs plus a Tape Loop, so you could have the Cable Box (not the TV) audio; and two (or three using the Tape Loop) other analog sources. NOTHING should need to route to the TV first. The Bose should get the audio from whatever you're watching directly from that source.
If the Cable Box has only one analog audio output available but the TV has a digital one
Since an analog audio output can be split you could 'share' the cable box audio with both the TV and the Bose. Digital audio may also be possible between the Box and the TV.
Jan 10, 2011 | Bose Lifestyle V20 System - black Theater...
Alex
You can connect an iPod to your Bose V30 using an ipod dock, or simply with a mini-jack (headphone jack) to RCA cable plugged into your V30's Audio-In ports.
I hope that helps.
Download Bose LifeStyle V20 User Manual
Sep 13, 2009 | Bose Lifestyle V20 System - black Theater...
The remote for Bose lifestyle V20 system does not work with Apple TV. I have component video coming out of the Apple TV into the Bose V20 system and then HDMI from the Bose V20 to a Sony Bravia HDTV. I...
Gerry
May 01, 2009 | Bose Lifestyle 20 System
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
