Question about Acer AL1916W 19" LCD Monitor
Acer 1916W No image on screen any more.
I have one of these and I just LOVE this screen.
My problem is that the screen comes on for a few seoonds then goes off but the light is still green so some signal is still being received obviously.
Now it doesn't come on at all but still senses an input signal.
Could either the backlights or power supply be the problem.
Also how do you get the power supply out. I have opened my monitor up but can't get the power supply cage out.
Is there a guide to dissassemble this monitor?
  • choccieLover Feb 08, 2010
    I don't have access to a camera at the moment..
    However I have removed the power supply board and it looks like the capacitors have blown. Several of them have bowed tops on them and dark marks.
    From what I have read this is a very common issue with this monitor and once the capacitors are replaced I will put the board back and see what happens.
  • Bud Martin
    Bud Martin May 11, 2010
    Please post some pictures then I may be able to guide you, see my photos here:http://s807.photobucket.com/home/budm/al...
  • 11,361 Answers
As you can see at photos I post on photobucket.com, you will see mot monitors are bad due to bad caps. http://s807.photobucket.com/home/budm/allalbums
You should replace them with LOW ESR 105C caps, I use PANASONIC FM or FC series from DIGIKEY, otherwise they will not last.
Posted on Feb 08, 2010
Hello My acer 1916W LCD Monitor Screen will not light up after turning my desk top Computer on.. Although the start light lights up okay My Screen stays Black. It only lasted over 6 months I am now using a...
you need to reset the bios in the computer take the littel battry out inside with the power of then wait a min or two re insert boot and c if that works
Apr 05, 2011 | Acer AL1916W 19" LCD Monitor
Acer 1916w Auto config. problem, every 5-10seconds, re-adjusts, makes it almost impossible to watch. any ideas for the DIY guy? thanks!
Obviously you've checked the connections are secure both sides? - thats the usual culprit.
Otherwise take it out and leave it off (power unplugged also) for minimum 5 minutes and that will clear any memory and capacitors, then try again.
Oct 29, 2010 | Acer AL1916W 19" LCD Monitor
I have a 19" ACER model AL 1916W wide screen and in the middle of doing something, the screen will black out and then come back on showing the ACER logo and continues on the page I'm working on...this will...
It proably has dying DC filter caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 13, 2010 | Acer AL1916W 19" LCD Monitor
Acer 1916W flickers which started 2 days ago. Can this be corrected?
Borrow replacement monitor and if good, not usually untill a part is replaced.
If the same, then fault is in the PC.
May 10, 2010 | Acer AL1916W 19" LCD Monitor
ACER Al 1916W Asd service manual
dac-19m005 power light comes on then goes off
Jan 08, 2010 | Acer Computers & Internet
Acer 1916w flickering
Its either going to be a problem with puffy capacitors on the main board or the lcd is going bad on it cause the backlight can't stay on.
The cost of fixing the monitor may be more then what a new one is worth but you wouldn't know unless you bring it to a repair shop and have them look at it.
Try another known working monitor to see if you get the same symptoms, if they go away then you know the original monitor is bad. if you get the same symptoms then the video card is bad.
Jun 26, 2009 | Acer AL1916W 19" LCD Monitor
Repairing the MB for the (Acer) AL1916 monitor
http://www.eletromaniacos.com/Downloads/Monitores/Acer/acer-AL1916v.pdf
Apr 24, 2008 | Acer AL1916W 19" LCD Monitor
Monitor resolution conflict
Install the Drivers for your New Monitor and then try increasing your resolution. If fails to solve, contact your Monitor Vendor (Seller).
Sahaja Yoga is FREE OF CHARGE and is the MAHAA YOGA.
Apr 23, 2008 | Acer AL1916W 19" LCD Monitor
Acer 1916w dissassembly
dear alanwilson04
if your monitor is under waranty then it is better to give to the shop from you have purchased.
if not then you call a qualified person to solve the problem because working inside the monitor is dangerous
Mar 04, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
554 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
