Question about Philips 32PF5320 32 in. HD-Ready LCD Television
Multiple issues with tv
  1. When changing channels on my tv the channel number stays on screen and same thing with my volume; when turning up or down the volume the volume menu stays on the screen.
  2. Furthermore, I cannot see the channel number when trying to change the channel to a specific one with the given remote with the TV.
  3. Lastly, captions don't turn on when activated.
Basically, all the menus wants to stay on the when used, I cannot see the channel I'm trying to put and captions for the TV will not turn on,
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Posted on Jul 26, 2008
HOW DO I GET GIG1 OF MY JVC TV SCREEN
Is it a 4k set? If so, that is gig #1 input and you must use the remote to switch around the inputs to the one you have connected.
Feb 11, 2015 | JVC Televison & Video
The volume of sony wega kv-sw29m61 set always to maximum when it turned on
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Jan 16, 2010 | Televison & Video
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
I was able to program my Comcast remote to control the volume of my tv, but was unable to get it to change channels. Is there something else that I should do?
Controlling the TV power and volume is probably all you'll be able to do with that control. The Comcast remotes are meant to be used with their converter boxes, and normally people want to change channels on the box while the TV stays on the box output channel (usually 3, sometimes 4). The remote's channel up and down buttons and number keypad only send out the codes recognized by the converter box. You'll need to fall back to the TV remote if you want to control more than power and volume.
May 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA TV Model Number KD27FS170 volume problem
my sony trinitron is blinking six blinks and I cannot turn it on, please help
Nov 22, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV turns itself on, keeps changing it's own channel
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
Jul 06, 2008 | Televison & Video
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Volume and chanel number stays displayed
Mar 22, 2008 | Philips 32PF5320A 32 in. LCD Television
Ghosts?
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
SPECIFIC FIX FOR GE 32GT660
I have the same problem, except that it would turn on by itself and then start changing channels. I had a can of compressed air and sprayed the button areas to see if there were sticking. It worked for a coupe of days, then started happening again. So I searched the web and found a response to a question someone else posted and the ensuing reply "most likely you have one of 2 things going on one is the foam between the buttons and the switches or you may have a switch getting leaky and would need replaced" Looks like I may have to taking the cover off and find some type of electronic cleaner, or replace the buttons. I find it odd that I got hits for the same issue with the same model. hhhhmmmmm?
Nov 21, 2006 | GE 32GT660 32" TV
Philips 32PF5320 32 in. HD-Ready LCD Television Logo
300 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
