First check fuse #7 and #16 in the passenger side dash fuse box, however I've seen this happen allot on this body-style of Odyssey's. Here's a quick check you can perform: Operate the rear vent window switch and listen for a 'click' in the rear of the van next to the vent window. This is the relay 'clicking'. If you hear the relay 'Click' you now know that your getting power in the circuit. This means that the vent motor is faulty. This is a common failure and they usually go out in pairs, so the other side maybe on its way out too. If you don't hear the 'click' than you'll have pin test the multiplex control circuit for a fault.
-hope this helps
Check relay or a fuse or you have a faulty switch
SOURCE: Right rear window of 2004 Honda Odyssey will close.
you can close it by pulling the door panel and removing the electric motor that raises the window, then lift the window closed and reinstall the motor, but the motor is most likely defective so if u go to all that hassle just replace the motor.
SOURCE: Passenger side rear power window is not opening
the rear side window vent motor is bad, u need to replaced it...common on these vans...i hope its the left rear and not the right....right is a little more difficult re installing due to the rear a/c ducts
