Question about Lexmark Office Equipment & Supplies
It says my print spooler is not running? - Lexmark Office Equipment & Supplies
  • 1 more comment
  • thirdasst Feb 06, 2010
    well i tried this and my printer still wont print screen. my son thinks it starts and then shuts down?
    my print spooler is not running what can i do?
    well i typed in services.msc and nothing happened now what?
  • 542 Answers
Check whether the printer spooler service is running. For this type services.msc in run menu and start the printer spooler services, if it is stopped.
Revert back for more assistance.
Posted on Feb 06, 2010
  • Rajesh Pai
    Rajesh Pai Feb 06, 2010
    Click start and then type services.msc in run menu then enter Or right click on mycomputer and selet manage, then expand services and applications, under that open services. Right side of the services, check whether printer spooler services are running, if not run the same by selecting the service >> right click >> start.
  • Rajesh Pai
    Rajesh Pai Feb 14, 2010
    I didn't receive any update from you? Hope your problem got resolved!!!
    Revert back for more assistance and give your valuable feedback/rating for the solution provided.
    Thank you for using Fixya.
Here is how to fix this problem: Right click on "My computer" and then select "manage" and then select "services" Open that up and find the printer spool service and then right click on it and click on "properties" and then click the "Start" button and also under a drop down menu change it from "Disabled" to "Automatic"
http://www.neowin.net/forum/topic/445246-print-spooler-service-not-running/
http://bytes.com/topic/net/answers/654183-print-spooler-not-running
My printer spoler is not working
Hi g k,
Have you tried restarting the print spooler from services?
Start the Print Spooler service from the Services console
  1. Click Start, click Run, type services.msc, and then click OK.
  2. Right-click the Print Spooler service, and then click Stop.
  3. Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
  1. Click Start, click Run, type cmd, and then click OK.
  2. Type the following commands at the command prompt: net stop spooler
    net start spooler
    exit
    Note Press ENTER after each command line.
Hope this helps, and please rate:)
Gary
Aug 01, 2013 | Samsung Office Equipment & Supplies
Print spooler is not running
Please try these steps:
  1. Browse to Start -> Run... and type NET STOP SPOOLER (this will stop the print spooler service)
  2. Type NET START SPOOLER (this will restart the print spooler service)
Try to print again to verify that the problem is fixed.
Feb 24, 2012 | Lexmark X1150 All-In-One InkJet Printer
Printer won't print from computer
Try the steps below to clear the print queue and restart your print spooler:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Jan 11, 2012 | Lexmark X5495 All-in-One &USB...
Spooler
Try the steps below to re-enable your print spooler:
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Dec 17, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Only printing 7%
If you're using Windows, it could be that your Print Spooler is not running properly. Please follow the steps below to fix the problem:
2. type in NET START SPOOLER (this will restart the print spooler service).
Oct 10, 2011 | Lexmark X4650 InkJet Printer
Z615 Error message,Printing Failure,current print job canceled,print status 15% completed,shows cartridge info.Power light blinks on-off,have reinstalled driver,rebooted windows. Widows XP
It could be the Print Spooler service on your computer. Make sure the service is running. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 24, 2011 | Lexmark Z615 InkJet Printer
Operation could not br completed. The print spooler service is not running
Hi There,
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 :
* Start > run > services.msc > ok
* Select the service name called print spooler from the list.
* Check the status on the print spooler service, if it is stopped, then right click and select start or restart.
* Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK )
In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok
* Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler)
* Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service)
* Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Enjoy printing !!
Oct 22, 2010 | Office Equipment & Supplies
What does it mean when i get the error message print spooler services not running
you need to turn it on, Go, . START>>RUN>>services.msc enter. When the services screen comes up, scroll down until you find the "Print Spooler" Enable it, Start it, and set to Automatic, reboot, ya good to go.
Mar 15, 2010 | Brother HL 2140 Laser Printer
My print spooler is not running
If you are getting a message that your print spooler service is not running, possibly you have the print spooler service turned off.
To start the print spooler service in XP:
Click on Start
Click on Run
Type "services.msc" and hit Enter or press OK
In the services window look for "print spooler service"
Click on the Print spooler and on the top left corner Click on "Start"
Reboot the computer. You should be able to print now.
Please get back for any further assistance.
If you find this resolution helpful, please do not find to leave your comments and ratings.
Thank you for choosing Fixya.
Feb 26, 2010 | Canon PIXMA iP1600 Printer
PRINT SPOOLER NOT RUNNING
When I try to print, a notice appears that the printer spooler serviceing is not working.How can I solve this problem?
Jul 31, 2008 | Lexmark X75 All-In-One InkJet Printer
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
