Question about Keurig 5048 My K-Cup Reuseable Coffee Filter
K-Cups disappointing My reuseable K-Cup coffee filter is real disapointing, coffee not alot of taste but the worse is so messy to use, water goes all over and not in the cup. Tried several ways but doesn't work good. K-Cups work good and coffee is good Thanks Wanita Caldwell .
I had same problem and called Keurig. They advised me that the gasket in the upper portion, where the top needle is needs to be brought down about half way, almost even with the bottom of the top needle. Be careful not to poke yourself. I brewed a cup with the resuable filter assembly and it worked great. It should stay in that position until you use an actual k-cup. When using it will push the gasket back up, as it needs pressure to puncture the hole. To go back to the resuable filter, you will need to lower the gasket again. She advised me that they are working on a fix for this issue and will notify you of any replacement parts, as long as they have your current contact info.
Posted on Oct 04, 2010
  • 1 more comment
  • morrisg636 Jan 16, 2011
    Yes, pulling down the gasket to the level of the needle, no water is escaping for a strong cup of coffee. Remember this processs has to be done each time you use the filter.
    Thanks
  • Marcia Chamberlayne Jan 18, 2011
    I just tried this and it works great. Thank you so much.
  • sailorgirl83 Mar 11, 2011
    Try this. It works. Pull the gasket down to make a proper seal with the reusable cartridge.
Three things I have done to help the problem you are having. 1- Buy stronger (dark roast) coffee and grind it to espresso setting 2- clean the rubber seal that is around the puncture tube for the top. This seal comes off really easy, just slide it down off of the stainless steel puncture pin. Make sure you know which way it goes back on. 3- When you brew your next cup, push down on the handle as the keurig is brewing until it is finished. Pushing down a little helps that rubber seal do it's job better.
Posted on Feb 06, 2010
Testimonial: "hello No, my k-cup is more trouble than its worth, coffee is still weak and water runs down the filter holder, can't use a thing like that. Thanks"
The coffee grounds are dry after the cup is brewed. It does not taste like fresh brewed coffee.
There's a needle that punches a hole on the bottom of the K-cup. That needle is clogged. Poke it with a paper clip or a thin wire to unclog it.
Aug 23, 2011 | Keurig 5048 My K-Cup Reuseable Coffee...
When using the reusable filter the coffee spews out in all directions with some of the coffee grounds
I googled this problem for 3 days. I was reluctant to try anything that would screw up my machine, as I have been very happy with it, except for the re-usable filter performance.
I wiggled the o-ring washer around top sharp thingie by maybe 1/8 inch and that fixed it. K-cups are running normal as well.
Feb 09, 2011 | Keurig 5048 My K-Cup Reuseable Coffee...
When using MY K-Cup reuseable coffee filter, the coffee comes out the drip hole plus water comes out of the bottom front of the K-Cup Portion Pack Assembly Housing splashing down onto the counter. I made...
Jan 30, 2011 | Keurig 5048 My K-Cup Reuseable Coffee...
Hi ,Does this coffee maker require filters? How many scoops of coffee for 60 cups?? DCU60T
No filters needed... just dump the coffee on the top pan....
I like my coffee strong and use about 1 cup per 10 cups of water....you may want to adjust to your tastes...
We use one of those units at church... they are a great unit...there they use a bit less cause many don't like it quite that strong...like 3/4 cup per 10 cups....
heatman101
Jan 28, 2011 | DeLonghi DCU60T Coffee Maker
Water does not pass through the Mr. Coffee. Just started out of the blue a few days ago. Heating element definitely works as steam just pours out the back of it but after running for 15 mins or so only...
Most of the time the coffee maker just needs cleaning with some Vingar sulution run though it.Do this about every 6 mouths.what happens specially with hard water it cluggs line up.So go to store buy small or big bottle of Vingar put about 1 cup in and half cup water aloud it to go though cycle's.Then or you may put two cups of vingar and two cups of water depend on how clugg it is.Then after done fill water despenser up to run Full pot like 12 cups,but donot over fill.that cleans it from the Vingar taste.You may want to do this twice.Hope this help,thanks for your question it was a good one.
Aug 08, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Does not complete the brewing cycle. Only cycles 1/3 of the water. 1-4 cup is NOT turned on.
First remove charcoal filter. Your coffee maker is clogged with hard water grime. Run 5 cups of vinegar through it twice, then follow with a couple of rounds of water to get the vinegar taste out. It will be as good as new.
Oct 04, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Kitchenaid 14-Cup has plastic, chemical taste
Run 1/4 cup vingar with a pot of water. The coffee is not finishing its cycle and some remains in the works. You may have to do this several times. Washing the carafe with ice and salt by swirling it around a few times until it sparkels clean. Last thing for a good cup of coffee is filtered water which will keep the unit cleaner too. :)
Sep 18, 2009 | KitchenAid KCM400 Coffee Maker
Funny tasting coffee
Vinegar/water cleaning is a good idea, but it won't necessarilly solve funny-tasting coffee. First, replace your charcoal water filter - you can get the Cuisinart brand-name replacements at Lowe's, Bed/Bath/Beyond, or Williams-Sonoma in most areas.
To do the vinegar/water cleaning, just pour 1/3 caraffe distilled white vinegar and 2/3 caraffe water into the water reservoir and brew it like it was regular coffee - I would simply bypass the self-clean function if your Cuisinart has one. Repeat up to 3 times, using a fresh batch of vinegar each time.
(if you have the caraffe-less DCC-2000, then just pour in 4 cups vinegar and 6 cups water).
Then run a full cycle of water. Then run a combo of 12 tsp lemon juice and 12 cups water (or 10 tsp and 10 cups water) to improve the taste.
On your next batch of coffee, use bottled water just to rule out any possibility that your local water supply may be contributing to funny-tasting coffee.
Now your coffee should be tasting fine again.
-Tha Mp3 Doctor
Apr 03, 2009 | Cuisinart Coffee Makers & Espresso...
Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Feb 14, 2009 | Gevalia CM-500 12 Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
2,172 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
