Question about Maytag Washing Machines
My washer died, but I am not sure if it is a belt, motor, etc. How do I open the unit to look?
  • 129 Answers
  1. It could be many things that would cause a washer not power up. The model # of your unit would help.
  2. At the bottom of the unit on the front edges look for 2 srews to remove. If you have them, remove the screws , lift the panel foward and unclip the front.
  3. Under the top are 2 bolts, remove them and the top lifts upward. Be careful not be hit with lid .
  4. If no screws at the top of the unit in the front under the lid top. Use a blade of a butter knife, push the 2 clifs (1 on each side of unit) inward releasing the front panel pull the panel outward and lift up to release.
  5. There are 2 bolts under the top. Remove the bolts and lift upward on the top careful not to be popped in the head with the lid.
  6. THis gets your unit open.
  7. To check out your unit, first check voltage at outlet, you need 120 volts.
  8. Listen for clicking of the timer, turn the dial to different spots.
  9. Lid switch shorts causing unit to stop, it is behind timer and under the lid.
  10. Some units have a micro-switch behind the timer, 21 amps.They short out easily.
  11. The motor will short out this will make a humming noise.
  12. The power cord may be damaged not letting power to the unit.
  13. The model number helps you locate the problem faster.
Posted on Feb 06, 2010
My washer wont spin
Do you still have the tech sheet that came with the machine on the back if not it would be worth it to call a service company does it drain if not will not spin if it does drain could be control not outputting voltage or a bad motor control unit a bad motor etc. I assume the unit agitates could be something simple as the belt broke.
Jan 21, 2014 | Maytag MAH6700AWW Neptune Front-Load...
How do I check the solenoid for the agitate/spin cycle?
This is a known problem with the motor, not the solenoid!!! You may have to replace the motor. A way to check is when it stops, unplug the power cord and touch the motor side frame. If the motor is hot that's your problem. Be sure to unplug the power plug to the motor and look inside the connector for a burnt spot. You might just need to replace the connector.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Jan 21, 2014 | Maytag Ensignia MAV4757AWW Top Load Washer
WASHER WILL SPIN AND DRAIN BUT CLOTHES ARE STILL PRETTY WET
If its a top load washer it will be a slipping clutch or your motor is slowly dieing.
If its a front load washer could be a loose belt, or dieing motor.
Jan 07, 2011 | Washing Machines
Machine won't spin.
Could be a lot of causes (worn/broken belt, bad switch, broken pulley, bad motor... etc). If your not sure of what it needs/ unsure of the repair process you'll either need to call a repair man or replace unit.
Oct 23, 2010 | Whirlpool LTE5243D Top Load Stacked...
Hi, my candy washing machine is not spining.i open the back to see the belt had fall off ,and not snap.i put it back but it won,t spin. help
not spinning can be related to door lock the door is a saftey switch if not working correctly will not spin but this is for front loader unit also if the pump doesnt drain in the time it should unit will not spin u also could have a failed motor ,motor control etc would need model # to be of any real help most machines have common prob
Apr 29, 2010 | Candy CN146 Front Load Washer
No spin cycle
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
Jan 16, 2010 | Washing Machines
Washer will not spin motor is not spinnig
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
Jan 02, 2010 | General Electric WHDSR316G Top Load Washer
Kenmore front load washer 417.41142000 drum banging while spinning
Hi...
Try to check this
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Good luck !!!
Regards
PCmania
Jul 08, 2009 | Frigidaire FTF530FS Front Load Washer
Washer won't spin. Worked fine 2 days ago, no unusual noises, etc. Just won't spin
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Jan 12, 2009 | Washing Machines
Washing machine won't spin or agitate
May 29, 2008 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
