Question about Sony VAIO PCV-V200G PC Desktop
Sound & internet
A year or so back we had a lighting storm/had unpluged unit.The next day
when I got home from work,my wife said the sound had quit.When I check
ed it out I found that the phone line had not been unpluged.Now the unit
has no sound & will not connect to the internet.I got a new modem from
Sony but no luck.Have tryed to get parts manual with no luck.Everything
else works fine.Can You please help.
  • sonyhoo Feb 21, 2008
    This may help >
    1) sound card = when you try to use it >error
    not installed.
    2) modem= error 633 already in use or not configured properly
    Have tryed the 1394 connection to a good PC didn't work.
    Thank you.
    Genius:
  • 3,587 Answers
Hmmm...well..let's see..
how do you usually get on line, Modem?
and open up the control panel, and check the sound settings,
Posted on Feb 21, 2008
S1730 sharper image ionic breeze GP
So you need another bulb correct
To order replacement lamps directly from The Sharper Image,
call 1-800-344-5555 and order item number SI922.
Lamps are effective for about 12 months of continuous use.
Dec 02, 2007 | Sharper Image Professional Plus Ionic...
Nothing shows up in the display. This has only been recently after a power glitch. The display lights when a call is made or received.
I unplugged the base unit from the wall for more than 10 minutes. Sometime after I plugged it back in (not immediately)the display re-appeared.
Nov 16, 2009 | Panasonic KX-TG2631 Cordless Phone
Phillips hts3410d no sound VERY dim led
Have you had any thunderstorms recently in your area? if so, this could be a pulse sent threw your system form an electrical storm. this happens often during dangerous thunderstorm activity. Also, your electrical wiring in your home can produce this as well due to a faulty circuit breaker box or lose ceiling fan hook ups. the best scenario could be a defective product. this way, you can get a full refund or a replacement set up.
Jan 28, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
No sound
Sometimes, an electronic pulse can cause this protect mode. this can come from an electrical storm or, bad circuitry in the home. Unfortunately, you may have to repackage and send back to the manufacture for repair.
Jan 26, 2009 | Audio Players & Recorders
No sound
I unplugged it for about 10 sec. to reset itself. Problem solved..................
Thanks
Randy Deer
Sep 23, 2008 | Panasonic SC-HT500 System
Tv turns on and then off
Good Day, ruschracing;
Storm? The first thing you should do is unplug the TV from the wall for 3 to 6 minutes (reset), then plug back into wall.
If that does not help, then you should call an authorized service center to give you an estimate for the repairs. OR call your home owners insurance company.
Good Luck, big IRISH.
Jul 25, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Mom's tv
sounds more like a solder issue.actually leaving the unit plugged in may actually help a solder problem as the standby voltage is present and sometimes solder tends to fix itself with voltages present.
Feb 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
KOSS KS5190 DIGITAL HOME VIDEO AND AUDIO ENTERTAINMENT SYSTEM
When your wife was painting did she have to move the unit or unhook it for any reason? It may be a loose connection in the wiring in the rear of the unit. If your are comfortable working on electronics and checking the connections did not work and unplug it for a day and plug it back in, does not work. then look under the lid see if there is a sign were paint got in should be easy enough to find. But I do not know of A good repair if that is the case. Other than make sure the unit is unplugged and clean the affected area with Robbing alcohol. Let it dry before resoring power.
Jan 06, 2007 | Koss KS5190 System
Problems with RCA RT2620
I have this exact problem, it appears the power on/off switch no longer works. After re-setting by unplugging the unit, use the remote only. As for the display, I find that if I turn the home theatre on last, the unit works and if I turn it on first, it behaves as you described.
Nov 20, 2006 | RCA RT2620 Home Theatre System System
Sony VAIO PCV-V200G PC Desktop Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
